Thread: Turn signal lever....
11-30-2011, 01:53 PM #1
- Sep 2009
- Houston , Texas
Metallic Pewter- 2002 SLP Firehawk
Its actually my high beam switch that is not engaging. Its very limp and will not switch them on. Turn signals work, wipers, cruise control, everything just not the high beams. Anybody know how to fix this? If i have to replace the whole lever where would I get it and how do i remove it? Thank you all in advanced.
Daniel
12-01-2011, 10:47 AM #2
- May 2011
- minden la.
black- 02 z28
Its most likely just the dimmer switch. Mounted on top of the column about halfway down connected to the turn signal lever with a rod. Usually have to drop the column to get to it
12-01-2011, 05:10 PM #3
- Jan 2009
- North Jersey
^^This. Simple fix that takes under half an hour.
12-02-2011, 08:05 AM #4
- Sep 2009
- Houston , Texas
It is really limp. Has alot of play, I don't even feel the rod that goes to the dimmer switch. If I do this myself, could I cause te air bags to go off? Stupid question maybe but I got quotes at 200 without them knowing what else they needed. Anybody have a link to somewhere that would guide me how to get in there to fix it myself?
12-03-2011, 03:24 PM #5
- Sep 2009
- Houston , Texas
ok guys i found my problem. I was looking around and this little guy fell out when i took of the covers of the turn signal lever.
P1000452.jpg This is a picture I took from google.
I need to find a way to put this guy back. The way it works is the turn signal rod pushes on this guy witch then pushes on the dimmer switch rod. Only picture online i could find online is this one.
Of course this is not a trans am but its the closes thing i could find. I can not see behind the turn signal switch though. I wanted to ask one of you willing to take their covers off and take a pictures of the actuator switch so i can figure out how this sucker goes back in. I would appreciate it.
12-05-2011, 11:53 AM #6
- Jan 2009
- North Jersey
Hmmm. I think you will have to remove the steering wheel and airbag to put that piece back into the column. Judging from the pic, looks like that piece just slides back into place. Let us know if you need anything else. Do you have a Chilton or Haynes manual?
Turn Signal
By wkstyle in forum Firebird / WS6Replies: 5Last Post: 09-30-2015, 06:19 AM -
Turn signal lever crappy
By Cutlass in forum General HelpReplies: 23Last Post: 06-04-2008, 02:24 AM -
Turn Signal lever problem
By squeals99 in forum LT1Replies: 5Last Post: 12-02-2007, 05:31 AM -
how do you replace turn signal lever
By ls1freak in forum General HelpReplies: 4Last Post: 01-04-2006, 04:34 PM -
broken turn signal LEVER
By speede in forum General HelpReplies: 1Last Post: 09-26-2005, 09:28 PM
