Results 1 to 16 of 16
Thread: Cutting off rear bump stops
03-03-2008, 04:32 PM #1
- Sep 2005
- Mississauga
Black- 1994 Z28 1LE
Has anyone bottomed out their car?
I chose to completely cutoff the rear bump stops to tuck in the tires as much as possible (custom wheels).
Am I asking for trouble or is that OK?
Jason Polzer
1994 Z28 1LE
03-03-2008, 04:43 PM #2
I would yes that it was a bad idea. But tell us what you got!
Example:
Wheels
Tires
Suspension
and so on...
03-03-2008, 04:45 PM #3
03-03-2008, 04:50 PM #4
- Sep 2005
- Mississauga
Black- 1994 Z28 1LE
So what do I do now? The rims and rubber needed the bump stops completely gone to fit how I wanted. No moving, trimming, or cutting in half would work.
What do I do now?
Jason
P.S. they are Enkei Wins widened to 17 x 10.5 with just over 8" backspace and Goodyear F1 315 rubber.
03-03-2008, 05:22 PM #5
03-04-2008, 08:31 AM #6
- Sep 2005
- Mississauga
Black- 1994 Z28 1LE
03-04-2008, 04:18 PM #7
03-04-2008, 04:25 PM #8
I ended up swapping to the Z28 bump stops for my 02 SS since I was bottoming out on the passenger side. Big improvement over the SS bump stops. I am lowered with hotchkis springs. Are you jacking up the car from the "pumpkin". If you are jacking up the rear of the car from the side the wheels will angle in and hit the bump stops. But its generally a bad idea of removing them completely.
2002 Artic White SS 35th Wheels|Full Hotchkis Suspension|Koni SA|Magnaflow CME|SLP lid|www.fquick.com/The_Guz
03-04-2008, 05:59 PM #9
- Sep 2005
- Mississauga
Black- 1994 Z28 1LE
Just go the car back from www.cdnperf.com tonight:
http://www.cdntechnologies.com/camar...delivered.html
http://www.cdntechnologies.com/camar...elivered2.html
315 Goodyears on 17x10.5 custom widened wheels
03-04-2008, 06:47 PM #10
Where do the tires rub?
03-04-2008, 07:09 PM #11
- Sep 2005
- Mississauga
Black- 1994 Z28 1LE
No where!
But I had to completely get rid of the rear bump stops (could not just trim them) and had to trim the part that they bolted to on the body completely away.
So now I am trying to get some kind of bump stop invented in case I bottom out to save my tires and possibly my life.
Or should I not worry about it? Perhaps I will never bottom out?
Jason
03-04-2008, 07:11 PM #12
03-04-2008, 07:28 PM #13
- Sep 2005
- Mississauga
Black- 1994 Z28 1LE
03-04-2008, 07:29 PM #14
- Dec 2006
- Lake in the Hills
Shhh! There's a- hooker in the trunk
when we put my new rims/tires on, my idiot bf cut my bump stops off. i was MAJORLY PISSED. but i havent had any probelms so far. the cars lowered .5 in in the back too. no one sits in the back of my car and the only really heavy thing that is in the back is my box with subs.
03-22-2008, 05:23 PM #15
- Mar 2008
- Calgary,Alberta
Can you move them to the inside or put them on the front link bar?
03-23-2008, 07:46 AM #16
- Jun 2002
- Montreal, CANADA
you can always get strong stoppers on the shocks... there is a thread on frrax about that.
I'll put the link once i find it... look for it tomorrow.Eugenio_SS
Rear Bump Stops from Sponsor
By 1slowbusa in forum Suspension and HandlingReplies: 14Last Post: 08-13-2011, 12:41 PM -
Rear bump stops
By JayTA98 in forum General HelpReplies: 0Last Post: 04-03-2010, 04:06 PM -
rear axle bump stops
By 2000redcamaro in forum Camaro / SSReplies: 8Last Post: 08-27-2009, 09:24 PM -
Where Can I Get Some Poly Bump Stops (Rear Axle)
By CJREX in forum Suspension and HandlingReplies: 2Last Post: 01-08-2008, 11:01 AM -
Rear Bump Stops w/ Eibach Pro Kit Springs
By T/Aboo in forum Suspension and HandlingReplies: 4Last Post: 02-27-2006, 05:27 AM
