Results 1 to 19 of 19
Thread: (UMI) Subframe connectors
06-26-2008, 06:33 PM #1
- Dec 2007
- Minnesota
pewter- 2002 Tans am WS6 M6
I have a 2002 ws6 and I just put on a set of UMI subframe connectors two weeks ago. These were a set of 3 point bolt-ons and I was really surprised on the simplicity of the instalation. My dad and I work on it and in abput 45 min they were on torqued and done. They really look great and I rhink they added alot of drivability to the car.
If they is anyone one the swinging edge of this I would really go with them (UMI) a very happy customer2002 Trans Am WS6 M6
06-26-2008, 07:19 PM #2
I have the UMI weld in's. I have them only bolted in the back and they squeak a lot, i'm thinking about taking them back to the shop and getting the back welded also.
I notice that the car is a lot stiffer when doing burnouts, and it bangs 2nd too
06-26-2008, 07:24 PM #3
- Thornton, CO
UMI = My choice for suspension parts.
LMPerformance carries their stuff. I have talked to Ryan at UMI and he told me to push his stuff via LMP since UMI isn't a direct sponsor here.
06-26-2008, 10:28 PM #4
- Jun 2007
- corona ca
white, white and pewter- Rip99SSA4,74Z28M4,02SSM6
i have umi panhard lca's and adj trq arm, the only thing i can complain about is how the thing bangs the floor board when i do a 2nd gear drop or how low the trq arm hangs because of the crossbrace mount but it does have a saftey loop, im going to get some subframes soon, deff gonna be umi,
06-26-2008, 10:33 PM #5
- Thornton, CO
Lowered, HID's, tinted.
06-26-2008, 10:37 PM #6
- Jun 2007
- corona ca
i would have to agree 1billion%, on another note, umi's installation is very easy, all except the relocation brackets, but most of my frustration with those lies with bolt on printed right on the instructions and adds for them, when in fact they are far from bolt on and require cutting and bleeding your brakes to install them,.
06-27-2008, 01:17 PM #7
- Dec 2007
- Minnesota
Ya on the Site Sponser thing I did get them off the Sponsor page Worked out really well
07-08-2008, 02:27 PM #8
I"m also a proud UMI Suspension Customer
PHB, PHB Relocation, STB and SFC (Bolt-in)
07-08-2008, 07:27 PM #9
- Sep 2007
- Philly+Glenmoore, Pa
I have the UMI 2 point weld-in SFCs and they are amazing. I could really tell a difference in the ride. Every one who doesnt have SFC on their fbody needs them asap!
07-09-2008, 05:01 AM #10
umi is the only thing i will put on my ta or sugest to any one else for that mater. i get my stuff from stranoparts.com also a sponser and a nice guy to deal with.
07-09-2008, 07:41 AM #11
- Dec 2007
- Brookville, PA
White- 2001 Z28
Why thank you.
Sam Strano
SCCA National Champion (x6)
SCCA ProSolo Class Champion (x5)
2009 SCCA ProSolo Overall Champion
Owner--Strano Performance Parts
814-849-3450
07-09-2008, 08:01 AM #12rapter34Guest
they are being welded on as we speak with weld on relocation brackets and UMI single ajustable LCA. can't wait
07-09-2008, 10:35 AM #13
- Apr 2006
- Jeffersonville, Indiana
Monterey Maroon Metalic- 2000 Z28
I have the 3 point UMI SFC's. This is truly a must do suspension mod. I had to cut off one of the driver side beams because it wanted to share the same space with my Y-pipe. I also have the adjustable LCAs and PHB from UMI although they aren't installed yet. I will have them put on during my next allignment. UMI FTW!
07-09-2008, 02:09 PM #14
Do these SFC's help out with 60 ft times? I have drag radials & can't get my 60 ft time below a consistent 2.0xx. How much would these help out????
07-09-2008, 02:14 PM #15
SFCs should definitely help out
07-09-2008, 02:17 PM #16
- Dec 2007
- Brookville, PA
White- 2001 Z28
No, SFC's won't help you in that aspect. Other parts may or may not depending on what the car is acting like now. Wheelhop or no? Track prep any good? Do you air down you DR's? Are they heat cycled to death?
Stiffening the chassis doesn't generally make a car launch harder. If it does it's due to massive twist that's messing with the suspension geometry. That's not happening in 2.0 60' car.
Suspension parts can certainly help, if you need them. But the first place to start it with the actual tire/track interface. You can't hook jack if you have bad tires and/or are on a crappy surface (or can't drive)....
I ran 2.0's on my stock GS-C's back in the day and I'm no drag racer....Last edited by Sam Strano; 07-09-2008 at 02:22 PM.
07-09-2008, 03:37 PM #17
+ 1 to that SCF`s help a bunch , mine drives like a totally different car !
1999 T/A FIREHAWK - SLP Lid & Bellow,LT`s & Catted Y & Power-Flo Catback , MSD & NGK , UMI 3P SFC,ADJ PHB,STB,LCA`s & Relos , Eibach Pro Kit , Bilstine/SLP Shocks , MAC Diff Cover , BFG & OE Wheels C5DD 18x9.5/10.5 , HID 8000K Headlights - Dyno`d @ 319.07 HP & 327.23 Ft-lb ( Tuned by Champ Motors )
07-09-2008, 05:39 PM #18rapter34Guest
just got them on about 3 hrs ago and wow what a difference! People were write I needed these done.
08-02-2008, 08:58 AM #19
- Dec 2005
- Pa
Thanks for all the kind words everyone
Question: Umi Subframe connectors
By davidz28 in forum Suspension and HandlingReplies: 4Last Post: 05-15-2010, 08:45 AM -
subframe connectors???!!!
By dadowd in forum ConvertibleReplies: 16Last Post: 05-12-2010, 07:25 PM -
subframe connectors
By Scanlamp in forum Rocky Mountain MembersReplies: 16Last Post: 06-20-2007, 07:25 PM -
i need help with subframe connectors
By 15T01Z28 in forum Suspension and HandlingReplies: 6Last Post: 06-12-2007, 03:25 AM -
Looking for subframe connectors....
By clg82 in forum Parts Wanted / TradeReplies: 2Last Post: 06-06-2007, 06:40 PM
