Results 1 to 2 of 2
04-05-2020, 04:08 AM #1
- May 2011
- Lakeland, MN
Metallic DK Blue- 99 Trans AM 6 spd
Video - how to upgrade from stock to LS6 Valve Springs
Upgraded to LS6 springs recently as part of my supercharged upgrade. Made a video to share the process.
01-14-2023, 11:26 PM #2
Upgrading from stock to LS6 Valve Springs requires removing the existing valve springs and replacing them with the LS6 springs. The process is relatively straightforward and can be completed in a few steps.
1. Remove the cylinder head: Unbolt the valve cover, unscrew the spark plug tube seals, and remove the head.
2. Unscrew the valve spring retainer: Using a valve spring compressor tool, unscrew the valve spring retainer.
3. Replace the springs: Place the new LS6 springs on the valve seat and reinstall the retainer.
4. Reinstall the cylinder head: Replace the valve cover, spark plug tube seals, and reassemble the head.
5. Test the springs: Start the engine and test the springs to make sure they are functioning correctly.
Following these steps should enable you to upgrade from stock to LS6 valve springs.
Are the stock Ls1 valve springs weak?
By importssuck in forum Internal EngineReplies: 5Last Post: 05-03-2012, 05:14 PM -
Stock LS1 Valve Springs...
By OnEbAdReDSS in forum Internal EngineReplies: 13Last Post: 08-08-2008, 01:17 PM -
New valve springs w/stock cam question
By rel3rd in forum Internal EngineReplies: 3Last Post: 08-15-2007, 12:56 PM -
STock Valve Springs
By redss454 in forum Internal EngineReplies: 6Last Post: 03-27-2007, 03:45 PM -
Stock valve springs?
By rnl35thss in forum Internal EngineReplies: 4Last Post: 02-15-2006, 06:15 PM
