Thread: 11" wheel fit without issue?
08-05-2009, 05:43 PM #1
Right now I have the stock WS.6 wheel with a 315 Nitto555r in the rear. I want to put a 11" wheel in the back and run the same tire. The tires fit back there fine now, so a 11" wheel shouldn't make a difference, right? I eventually want to lower the car with Strano springs, will this cause any issues?
08-06-2009, 05:56 AM #2
- Jun 2008
- Annapolis, MD
BLK/BLK w/CGM Stripes- 2010 Camaro 2SS/M6
17X11 TT2's fit fine in there so if it's some wheel similar, you'll not have any issue
08-06-2009, 08:34 AM #3
- Thornton, CO
Some cars will fit them without issue.
Others won't.
Hit or miss.
08-06-2009, 05:56 PM #4
Mine will scrape the outer edge of the passenger side tire but i think thats an issue with me not adjusting the panhard bar correctly. Even then i would have to hit a serious dip for it to rub when im alone driving. If i have a passenger it will rub alot more.
08-06-2009, 06:57 PM #5
Mine touch a bit, use a BFH and grind down the bump stop a bit.
08-06-2009, 08:04 PM #6
Seems to be T/a's don't have an issue but Camaros need the BFH or fender roller mod...
Wanted: 98-02 OEM 16" wheel "ABS" black background center caps
By JayTA98 in forum Parts Wanted / TradeReplies: 5Last Post: 11-05-2012, 12:40 PM -
Maryland "May Issue" System - Unconstitutional!!!
By wileyCoyote in forum Gun's & AmmoReplies: 10Last Post: 08-02-2012, 08:26 PM -
c6 corvette wheel...BIG ISSUE
By K_garretson23 in forum Wheels and TiresReplies: 6Last Post: 07-12-2011, 02:35 PM -
Rear wheel issue
By 6-Speeder in forum Wheels and TiresReplies: 0Last Post: 01-03-2009, 12:25 PM -
Wheel Stud Issue
By bspalmer in forum General HelpReplies: 5Last Post: 07-20-2008, 01:42 PM
