Thread: Moisture on oil cap
12-03-2007, 07:21 AM #1
- Nov 2007
- Oklahoma
Black- 2000 Pontiac TransAm
Moisture on oil cap
My buddy took off my oil cap yesterday when I was working on my headlight motor, just messing around. He found what looked like water or moisture on it. Is this bad, because it freaked me out a little bit. Someone told me it was penzoil oil because it was all sludgy looking. I'm going to go change the oil today since it needs it anyways. Give me some info, BAD, or nothing to worry about. It is still running fine.
12-03-2007, 07:42 AM #2
- Nov 2005
- LIVONIA,MICHIGAN
PEWTER- 2000 CAMARO SS #3821
The engine needs to reach full operating temp. to "burn off" moisture which is normal so if you are seeing moisture your trips may be too short or your engine temp. is too low to burn off the moisture. I would not believe the pennzoil oil stories causing your problem, maybe your stat. is too low.
12-03-2007, 07:56 AM #3
- Nov 2007
- Oklahoma
Yeah, I thought something like that was happening. I havent really started driving the car everyday yet. I am still working on selling my syclone. So the T/A is in the garrage.
12-04-2007, 08:26 AM #4
if it's sat a bunch or hasn't gotten up to operating temps a time or two it'll have a little moisture on the cap.....normal. What does the oil on the stick look like when you pull it?
12-04-2007, 08:48 AM #5
- Nov 2007
- Oklahoma
It looks fine, so I wans't that worried. Thanks for re-assuring me!
Help: Moisture in reverse lights 2000 T/A
By fbodyNATION in forum Firebird / WS6Replies: 6Last Post: 09-20-2011, 12:07 AM -
Question: Moisture inside back-up light.
By TheChad1371 in forum Firebird / WS6Replies: 42Last Post: 05-04-2011, 02:28 PM -
Fog Light Moisture Problems
By stockwellsm in forum Stereo and ElectronicsReplies: 0Last Post: 05-16-2008, 09:45 PM -
moisture in rear taillight
By SSpeed in forum General HelpReplies: 3Last Post: 07-18-2006, 03:34 PM -
moisture in parking lamps
By rhinojohn in forum General HelpReplies: 6Last Post: 11-21-2005, 07:33 PM
