Thread: moisture in parking lamps
11-18-2005, 08:11 AM #1Junior Member
- Nov 2005
- NH
blk- 99t/a
ive had water build up in both my parking /directional lamps leading to bulb failure and corrosion. replaced unit with brand new one and today noticed some condensation inside new lamp housing. has anyone had this problem?
Thanks
11-18-2005, 08:22 AM #2Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Yep, most will drill holes in the bottom of the housing.
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
11-18-2005, 09:19 AM #3Story of My Life!!
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
11-18-2005, 09:52 PM #4Senior Member
- Sep 2005
- New York, NY
Collectors Edition Yellow- 2002 Pontiac Trans AM WS6
i used silicone to seal mine all around the housing... And if by some strange reason i needed to get in there all i would need is a razor to cut it off!!
11-21-2005, 08:07 AM #5Junior Member
- Nov 2005
- NH
blk- 99t/a
thanks
11-21-2005, 06:45 PM #6Detailing + Design
- Pittsburgh, PA
i totally needed this post like 2 days ago...ef.
oh well, i hope what i did lasts; i found a hole developed on teh top of the light housing and i put liquid weather strip adhesive on it....i also replaced both of the light harnesses. hope it works. where should i drill holes if need be? in the housing or in the harness?
11-21-2005, 07:33 PM #7I like the way yew tawlk.
- Blairsville, GA
Red- 2000 T/A WS6
I had to replace both lamps awhile back. They were just faded and cracked in the lenses, so water got in there every time it rained.
I haven't done anything like it yet, but I'd say you'd want your hole at the lowest point in the lamp itself. Sizewise, I couldn't imagine needing a hole bigger'n 1/8".
Help: Moisture in reverse lights 2000 T/A
By fbodyNATION in forum Firebird / WS6Replies: 6Last Post: 09-20-2011, 12:07 AM -
Wanted: Trans am front parking lamps
By pimpjames in forum Parts Wanted / TradeReplies: 0Last Post: 02-16-2011, 08:23 AM -
Fog Light Moisture Problems
By stockwellsm in forum Stereo and ElectronicsReplies: 0Last Post: 05-16-2008, 09:45 PM -
Moisture on oil cap
By BadA$$ in forum Internal EngineReplies: 4Last Post: 12-04-2007, 08:48 AM -
moisture in rear taillight
By SSpeed in forum General HelpReplies: 3Last Post: 07-18-2006, 03:34 PM
