Page 1 of 3 123 LastLast
Results 1 to 20 of 43
    I Love High-Explosives! TheChad1371's Avatar
    Slatington, PA
    2000 Trans Am WS.6
    Exclamation Moisture inside back-up light.
    I only have it inside my drivers side back-up light. What's the best way to fix this?
    "United We Stand, Divided We Fall."
    You know, I had the same problem with my drivers side headlight ??? Still don't know why. I took the bulb out and let it completely dry out and it happened again I even put a bead of silicone around the seam just in case and that didn't help either. It kept coming back. Thing is, we don't have a lot of rain or moisture in the air out here and it drove me nuts...
    But, for whatever reason, it's been dry for the last few months, even when we did get a few showers.
    It's a mystery
    TEXAS... U mad?
    Black / Stryker Blue
    2K WS.6/ 2K9 G8GT
    Its the lense to housing seal, not the bulb to housing seal...
    The lense is seperating from the housing... and soon your drivers side tail/brake lights will become very dim, due to this moisture seeping in there, and wilting the chrome lining inside the tail light housing.
    Member TA98's Avatar
    Mar 2009
    Maryland
    mines just like that. i have taken out the bulb and dried the lens out but it doesnt stay dry long
    Quote Originally Posted by T/A98 View Post
    I went as far as to keep the bulb out for days, all warm dry days... keep the hood popped so air could get to it and it had to be dry as a bone. Put the bead of silicone around the seam and thought for sure that would take care of it.
    And, without any rain, condensation built up in there again.
    Did the whole process again and haven't had an issue since
    Crazy.
    Mar 2009
    Maryland
    thats what happened to me. i took it out, dried it, reinstalled it and by that night it was foggy again with out any water at all
    Jun 2009
    Canada, Ontario
    1999 WS6
    Mine does the same BS except on the passenger side reverse light. I hope it doesnt effect the brake lights like someone mentioned before.
    TEXAS... U mad?
    2K WS.6/ 2K9 G8GT
    It will eventually...... The moisture, combined with heat of lamps, is detrimental to the chrome like finish inside the lamp assy..... The light will begin to appear "Dim"
    Jun 2009
    Canada, Ontario
    1999 WS6
    Ok so is there a fix for this that will stop it, or should I be ordering a new tail light assemblies?
    *Mine only appears after a wash, and then it goes away.
    Slatington, PA
    2000 Trans Am WS.6
    Well, as shitty as it is, at least this seems to be a common problem. I used to get water inside my taillight, i had to drill two small holes under the assembly for it to leak out and not build up. I suppose I could try silicone around the housing and lens, let it dry over night and see what happens. my front turn signals and factory fog lamps were cracked too. I just replaced the entire assemply up there, much better now. In time I will do the same with the tail lights too.
    TEXAS... U mad?
    2K WS.6/ 2K9 G8GT
    Did you see the thread about the fronts? You need LED bulbs, or you'll be doing it again soon. the DRL's use the brightest filiment in the bulb, constantly illuminated, thus creating extreme heat in a small enclosure.... Add water from a wash, or driving thru a puddle, and ....CRACK!!! you back to square one. LED replacement Bulbs (Available at truck stops) operate as bright, but not near as hot as incadescent.... Just food for thought
    TEXAS... U mad?
    2K WS.6/ 2K9 G8GT
    Quote Originally Posted by StrikerWS6 View Post
    LED's will help here as well, eliminating the heat, deters the effect that the water has on the chrome-like finish in the assy....
    Member knightryda01's Avatar
    May 2008
    Michigan
    midnight blue
    2000 Pontiac ram air ws-6
    so have we came up with an easy fix?
    TEXAS... U mad?
    2K WS.6/ 2K9 G8GT
    Well, the start of the fixes is to eliminate the heat in both front and rear assys.
    Slatington, PA
    2000 Trans Am WS.6
    LED's in the turn signals or fog lamps? I had them both replaced for almost two years now, all is well....so far. haha.
    TEXAS... U mad?
    2K WS.6/ 2K9 G8GT
    Just the turn signals.... The fog lamps are glass housed halogen bulbs, and if they are broken, the likely culprit is rocks....
    TEXAS... U mad?
    2K WS.6/ 2K9 G8GT
    For anyone who doubts the heat, remove your taillight, take out a bulb (but leave it in the socket... activate your flashers ( which use the bright filiment ) and then see how long you can hold the bulb with your fingers. Now, keep in mind your flashing it, and the heat will become 3x that when it is made to steady burn.... thats the front. Now X thast by 2 when you are standing on the brakes at a red light, and thats the rear... . per side.
    Slatington, PA
    2000 Trans Am WS.6
    That's a good point. Do the led's fit into the factory slots, or do you need to get new wire harness too?
    Jun 2009
    Canada, Ontario
    1999 WS6
    This is real crap. Its so far the only thing wrong with my car *knock on wood* im gonna see if a bead of silicone around the reverse light will get rid of the moisture and I will report back.
    The other lights dont cause any problems at all.
    TEXAS... U mad?
    2K WS.6/ 2K9 G8GT
    Quote Originally Posted by TheChad1371 View Post
    They make replacement bulbs, that fit right into the sockets.... Again, the best place I have found to get these is a truck stop, and.....
    NOTE:
    DO NOT get Red LED's to replace the tail lights.... Get WHITE... The reds WILL NOT be bright behind the red lense..... TRUST ME.... GET WHITE!!!!!!
  1. Performabuilt holiday giveaway is back see inside
    By performabuilt in forum Automatic Transmission
    Last Post: 12-21-2013, 06:44 PM
  2. PerformaBuilt Back to School sale see inside
    Last Post: 08-02-2012, 05:23 PM
  3. Fog Light Moisture Problems
    By stockwellsm in forum Stereo and Electronics
    Last Post: 05-16-2008, 09:45 PM
  4. Moisture on oil cap
    By BadA$$ in forum Internal Engine
    Last Post: 12-04-2007, 08:48 AM
  5. broken fog light...pics inside
    By BLKbandit98 in forum Firebird / WS6
    Last Post: 11-16-2007, 02:41 PM
