Thread: convertible Motor
06-27-2016, 07:37 AM #1
- Jun 2016
- Lansing
Blue- 1996 Camaro Convertible
convertible Motor
i have a 95 Camaro Vert and suddenly my top no longer goes up by switch but it will fold down with ease. from what ive read it could be the switch or the motor fluids . can someone tell me where the relay is located or how to test the switch or how to check and fill the motor with more fluids please
06-27-2016, 07:42 AM #2
- Oct 2007
- Muncie, IN
00 TA PWTR, 98 VertTA NBM- 80 TA BLK, 80 Formula NBM
Pull the driver's side carpet inside the trunk. You will be able to see the hydraulic pump for the top. The reservoir is transparent so you can see the fluid level. Most likely it is low. If it is full, the pump is probably bad.
2000 TA, A4, LS6 intake, Magnaflow, WS9 hood, BMR STB, UMI boxed SFC, Spohn LCA, 9" Ford
1998 TA Vert, NBM, M6, Flowmaster, WS6 hood, WS6 airbox, C6 wheels, UMI SFC, BMR STB
1998 Bird, Black, V6, A4, 18" 077's, Wings West Body Kit
1980 Formula, NBM, 402BB, cam, DR timing, LT headers, 3" TD w/ flowmasters, TH350
1980 TA, Black, 301, bone stock
06-27-2016, 02:01 PM #3
Check out the stickies in this section (threads that are saved at the top of the forum) for the one about how to fill the top motor. It will walk you through what you need to know. You may just have had low fluid and pulled air into the system.
06-28-2016, 04:09 PM #4
- Apr 2014
This recently happened to me. Purchased a switch from eBay and now works.
Help: convertible top motor
By tripps in forum ConvertibleReplies: 2Last Post: 03-19-2012, 03:17 PM -
Convertible Oil for the motor pump
By sergiomarruffo in forum ConvertibleReplies: 1Last Post: 04-24-2008, 05:58 AM -
Need help pulling motor - broke motor at a road course event
By Doc99SS in forum General HelpReplies: 20Last Post: 08-24-2007, 05:57 PM -
convertible motor
By yodabill in forum ConvertibleReplies: 0Last Post: 06-19-2007, 06:02 PM -
Convertible top motor
By dj_phaedrus in forum ConvertibleReplies: 3Last Post: 12-04-2005, 05:13 PM
