Results 1 to 20 of 20
12-15-2008, 12:30 PM #1
Big Cam, What supporting Mods do i need?
I want to get a Cam set up but im stock all around. any ideas on a good sized cam with that will get me some power..i plan on getting headers, intake and heads in the near future so really the question is can i get a cam to run with stock components with not a lot of trouble?
12-15-2008, 03:22 PM #2
- Cape Coral, FL
Mystic Teal- 99 Trans Am & 01 CBR 929
it will work. you just wont see near the power that you want.
12-15-2008, 04:01 PM #3
thats what i figured but im getting the supporting mods; heads, headers and intake this summer.
12-15-2008, 04:05 PM #4
- Cape Coral, FL
to add to my original post. you will still need to upgrade your valve train and pushrods. but everything else can be stock.. you just wont have good results
12-15-2008, 05:15 PM #5
If you're a six speed I say get a clutch (Mcleod, Textrailia, Ram), and a rear end (Strange 12 bolt, Moser 9 inch) before getting a head/cam kit
12-15-2008, 11:30 PM #6
You are really going to want to do headers before cam.... also an intake manifold too...
then yea you can run some of the smaller cams without issue but with larger cams your deffinately going to want pushrods, springs, oil pump, and timing chain...along with your heads
12-16-2008, 05:10 AM #7
rather than getting a cam, get a set of long tubes instead and put the cam off 'til summer. it'll be easier install and the results will be better for an otherwise stock motor. if you don't have catback. . .get that too. the amount of stuff you will need for the cam swap: pushrods, springs, cam, tune. . .and the "might as wells" : lifters, timing chain. . .you will spend same/more money than the exhaust upgrade and you wont have the driveability issues.
-set of aftermarket heads will already come with springs to support cam, so you would be wasting your money on springs and a tool if you were to do cam swap now instead of waiting. also, some aftermarket heads requitre different length pushrods. so you could possibly waste more money on stock size and then upgrading them later. a big cam will REQUIRE a tune to get power/run right. your car will want to be tuned w/ long tubes will not be required. save all that money and do head/cam when youre ready.Last edited by side2000; 12-16-2008 at 05:14 AM.
12-16-2008, 10:32 AM #8
ya im kind of leaning towards just getting headers and an intake and doing the heads and cam this summer. I already 4.10's and i dont plan on doing the rear end until it goes. i do some mild racing maybe 20 times a summer im out at the track and when i drive her on the street 8 out of 10 times im shifting before it hits 3k RPMS.
12-16-2008, 11:49 AM #9
12-16-2008, 04:34 PM #10
12-17-2008, 11:19 AM #11
12-17-2008, 12:46 PM #12
12-17-2008, 03:03 PM #13
12-17-2008, 03:49 PM #14
- Cape Coral, FL
or if you dont do a search and/or read through any number of threads in the section then you will get an answer like mine which only answers the question and offers so real advice whatsoever
12-17-2008, 04:32 PM #15
Nothin like seeing a head and cam car at the track run 12s (or worse) cause he can't launch it properly (stock rear/clutch) to net a decent time.
12-17-2008, 05:21 PM #16
12-17-2008, 06:01 PM #17
well just be the guy tryin to beat his own trap speed record.
12-17-2008, 06:06 PM #18
12-17-2008, 06:10 PM #19
yea no1 listens to me, or believes what i say. . .everything i say is wrong. . . .and you are really intelligent.
12-17-2008, 06:31 PM #20
Best supporting mods for cam
By dethinboots in forum Internal EngineReplies: 13Last Post: 10-03-2014, 09:17 PM -
Question: heads and cam supporting mods?
By Professor Chaos in forum Internal EngineReplies: 33Last Post: 02-18-2009, 01:49 PM -
clutch and gears - supporting mods '98
By SpecterGT260 in forum DrivetrainReplies: 5Last Post: 08-15-2008, 04:44 AM -
FS: '99 TA, new 402 ls2 motor and supporting mods.
By djvaly in forum Cowhands, Local Parts and Fish BaitReplies: 3Last Post: 11-17-2007, 10:30 AM -
supporting mods
By llcooljosh in forum Internal EngineReplies: 7Last Post: 08-08-2007, 03:46 PM
