Thread: Squeaking sound?
07-04-2007, 04:44 PM #1
Squeaking sound?
i have a squeaking sound coming from the engine at first i thought it was the belts so i replaced them because they looked worn anyways so after i put those on i still squeaked and someone suggested air condtioner so i turned my air conditioner off and most of the squeaking stop but it still sounds like something is squeaking just not as loud?so does or has ne one had this problem or does ne one have ne clue what it could be help needed asap please!!
07-04-2007, 06:08 PM #2
I am the only one with this problem or what?
07-04-2007, 06:42 PM #3
- Jul 2006
- Westminster/Sykesville, Maryland
Red- 2000 Trans Am
did you replace both belts? I had to replace both of my belts, the idle pulley and the tensioner pulley before all of my squeaks went away.
07-05-2007, 09:44 AM #4
I'd suspect the tensioner pulley second as it is spring-loaded and has much potential for causing squeaks.
The reduced load when you shut off your air conditioning causing the reduced squeaking could point to this as well.
Screeching sound coming from rear of the car - sound clip.
By Tataocb in forum General HelpReplies: 45Last Post: 07-21-2016, 08:12 AM -
Help: Squeaking....
By flybird in forum Firebird / WS6Replies: 10Last Post: 04-06-2011, 01:56 PM -
Question: Chirping/Squeaking sound (Slave Cylinder)?
By manibot in forum Manual TransmissionReplies: 4Last Post: 04-08-2010, 05:01 PM -
'squeaking’ going on in my rear bad
By MotorDogStar in forum Firebird / WS6Replies: 8Last Post: 07-01-2009, 11:09 PM -
Squeaking Sound
By Fade2Black in forum General HelpReplies: 8Last Post: 11-14-2007, 01:42 PM
