Results 1 to 20 of 22
Thread: Water Pump Help.
01-17-2006, 08:46 AM #1gisselle19Guest
Water Pump Help.
OK here's the deal I dont have an LS1 I actually have a 1996 saturn sc2. BUt my friend uses this site and he's learned how to fix up his car. Also I'm a girl so I don't know much.
My water pump's bearing are shot according to a mechanic that looked at it. I have the part and everything I need. There are 3 bolts to take off the pulley that is also bolted to the water pump. I have taken 2 of the 3 bolts off the pulley but the last one is stripped. I've saturated th bolt with PB but still nothing. We are securing the pulley so it doesn't move with a strap wrench and using the craftsman 'bolt out' socket that works on stripped sockets but still nothing. I was wondering if anyone had any suggestions.
I have also tried to just take the water pump off with the pulley but there are 2 of 6 bolts that are completely inaccessesible.
HELP!!!1 thanks boys
01-17-2006, 09:09 AM #2M6TAGuest
sounds like you might have to get someone to pull the bolt out with a tool and die kit i think... drill out the bolt and pull it out... if i remember correctly
01-17-2006, 09:39 AM #3
- Crystal Lake IL
Pewter- 2001 Camaro Z28 M6
are you sure that the bolt is stripped and that maybe you might need a pully puller.
I'm not familiar with saturns. So I am not sure how the water pump is laid out.
Nonetheless, if the bolt is stripped you will need:
Screw/fastener extractor.
what you do is drill a pilot hole in the stipped bolt, then screw the screw extractor into the bolt. Once the extractor bites into the bolt you will be able to unscrew/back out the bolt slowly.
good luck, and let us know if you need more advice!!
01-17-2006, 09:45 AM #4
Never good to strip a bolt I did the pump in my girls 96 cavalier a few times...probably pretty close to your motor setup. Are you getting leverage on the bolt...I mean the socket isn't just spinning on the bolt right? I left the belt on...broke the bolts loose and then took the belt off...that way the pulley doesn't spin. Other then that it's all muscle and some scrapped knuckles....see if your dad or b/f and break it loose.
Also leverage is a little better from the front of the car...not the side. On the cavy the pump is on the passenger side right up against the fender/wheel well....if the saturn is the same way try it from the front. Only get replacement pumps from the dealer BTW...had to redo hers a few weeks later because it started leaking out of the weep hole...bought it at autozone....yea, sucked.
01-17-2006, 09:49 AM #5Originally Posted by ibanez7
01-17-2006, 01:33 PM #6Originally Posted by SeVeReDiStOrTiOnHammer - hammertime.us
2001 Light Pewter Metallic Camaro SS, 6 speed
K&N, SLP Lid, SLP y-pipe, GMMG cat-back, Lou's Short Stick - more to come!
01-17-2006, 03:40 PM #7gisselle19Guest
ok yes the setup is just as someone described above on the passangers side and inch from the wheel well. and i gorgot to explain it's not me working on it, I;ve have 3 guy friends look at it. And yes it's def a bolt(I'm not that dumb) the bolt wasn't originally stripped it became stripped after numerous tries to get it off. And my part is also from Autozone which sucks now bc i dont have the reciept. Is there anyone in the Orlando/UCF area that can help??? I'll pay I just can't drive it to the mechanic.
01-17-2006, 09:07 PM #8Originally Posted by gisselle19
You could try telling the folks at autozone you found a loose hose clamp. If they still won't take it back, just chalk it up to experience.
01-17-2006, 09:23 PM #9Originally Posted by gisselle19
As far as the autozone pump...if it's bad they'll replace it for free with no problem...besides the problem of having to reinstall the pump
01-17-2006, 09:26 PM #10
Oh... and of you:firedevil
01-18-2006, 09:58 AM #11
- Crystal Lake IL
i would try to help but we are too far apart.
have you tried calling a saturn dealer and speaking with a tech. The can be tons of help over the phone!
01-18-2006, 11:34 AM #12gisselle19Guest
Picture!!!!!!!!!!!
there that is me in the front. i attached the pic enjoy
thanks for all the help guys!!!! it's greatly appreciated
[/QUOTE]
01-18-2006, 11:39 AM #13
- Crystal Lake IL
damn your a hottie!!!
i guess i'm driving from chicago to orlando to help fix your car.
01-18-2006, 01:56 PM #14gisselle19Guest
well thanks!!!!
01-18-2006, 07:56 PM #15Originally Posted by gisselle19
01-20-2006, 12:08 PM #16gisselle19Guest
nope it's still just sitting inmy drive way
01-20-2006, 03:58 PM #17
Man, I thought the OLA would have jumped in to help you by now...
Orlando Leghumpers Association, where are you?
01-20-2006, 08:18 PM #18
So, there's something else in Orlando worth seeing besides Disney World & Universal Studios! N I C E. Tell your boyfriend that if he can't get your water pump out, then you're finding another boyfriend who's willing to pay to get the job done.... Good luck!
01-31-2006, 10:11 PM #19gisselle19Guest
i wish it was that easy!!
but i did end up getting the waterpump off(pulley attached). It did take some patience to sit there reach those last two impossible bolts. but we did get it off ! now i have to just buy another pully and bolt. thanks guys!!!
anyone looking for a cute girl that loves cars ad racing 'em??? lol
01-31-2006, 11:08 PM #20Originally Posted by gisselle19
I woulda came by and helped...but ahhhh....I live in cali
Question: Water Pump
By psycho_puppies in forum External EngineReplies: 4Last Post: 01-20-2011, 05:23 PM -
Question: water pump
By Pony_Eater in forum External EngineReplies: 8Last Post: 08-31-2009, 03:26 AM -
Water pump going out
By BMJ99Z28 in forum General HelpReplies: 9Last Post: 02-18-2009, 04:14 PM -
Do electric water pumps pump enough water for daily use?
By xinthenight in forum External EngineReplies: 6Last Post: 08-02-2007, 09:04 PM -
Water Pump?
By 5LtrBtr in forum General HelpReplies: 6Last Post: 05-18-2006, 08:44 AM
