Results 1 to 3 of 3
Thread: convertible top motor
03-18-2012, 08:24 PM #1
my top comes up and opens fine but when its time to close it it does work or even make a noise when i hit the switch...does anyone one know what to do other than change the whole pump?
03-19-2012, 08:04 AM #2
- Sep 2005
- NE Indiana
Black- 1998 Trans Am WS6 'Vert
Its your top switch. If the motor works in either direction, the motor is OK. The switch reverses polarity of 12V to the motor, so it has to be your switch.
I saw a thread somewhere that showed how to wire a pair of relays to handle switching the high current to the motor and save your switch from the wear and tear. Its alot easier and cheaper to replace a relay than it is this hard to find switch.
Johnny B - '98 "Triple Black" WS6 Convert, M6, All Options, ASC #3030 (1 of 50)
KBDDSFC, DGM C/F Tonneau, MTI C/F Lid, K&N, HPP-III, 160 T-stat, Pro 5.0
Link to Firebird Production Breakdowns
03-19-2012, 03:17 PM #3
JohnnyB is probably correct about the switch but just in case, have you checked your fluid level to ensure that you have enough fluid in the pump and lines. If unsure how, check the sticky on pump fill procedure.
convertible Motor
By JayMoung in forum ConvertibleReplies: 3Last Post: 06-28-2016, 04:09 PM -
Convertible Oil for the motor pump
By sergiomarruffo in forum ConvertibleReplies: 1Last Post: 04-24-2008, 05:58 AM -
Need help pulling motor - broke motor at a road course event
By Doc99SS in forum General HelpReplies: 20Last Post: 08-24-2007, 05:57 PM -
convertible motor
By yodabill in forum ConvertibleReplies: 0Last Post: 06-19-2007, 06:02 PM -
Convertible top motor
By dj_phaedrus in forum ConvertibleReplies: 3Last Post: 12-04-2005, 05:13 PM
