Results 41 to 48 of 48
09-27-2007, 02:53 AM #41
- Sep 2007
- Virginia
Black- 1998 Camaro Z28
Thanks for the quick response. I have an automatic with a shift kit already, which I don't plan to mess with. I'd like to reuse as much as I can from the LS1. Then upgrade at a later time.
I have access to a lift and I'll probably try to drop the engine from the bottom. The Haynes manual I have only shows how to pull the engine from the top. Have you seen anywhere that shows the steps for bottom removal or should I just buy a factory service manual?
Thanks again for all of the info.
Dennis
09-27-2007, 03:01 AM #42
Automatic! Eeek - not ideal if you want to go fast. Do they not make these with t56 tremecs? Shifting gear when YOU want is surely the way to go?
Mind you I am a Brit and hate Autos!
09-27-2007, 03:34 AM #43
- Sep 2007
- Virginia
09-27-2007, 03:56 AM #44
09-29-2007, 10:06 AM #45
- May 2007
- Columbia, MO
Medium Blue Metallic- 1999 Pontiac Trans Am
So did this engine come with the upgraded LS6 valley cover or oil pump?
10-03-2007, 01:16 PM #46
- Nov 1998
- Macon, GA
I did my LS6 swap in the summer of '04 BEFORE this CTS-V engine was available I believe...or at least that's what I tell myself since I spent an extra $2K for 12498399.
Anyway, I did a complete write up on my swap with a few pics and you can see it here:
http://www.banddirector.cz28.com/custom2.htmlBlack 1998 Camaro Z28 6-Speed: LS6 Longblock (405 HP) and lots more...
-View:
10-03-2007, 02:59 PM #47
- May 2007
- Columbia, MO
Did this engine come with the upgraded LS6 valley cover or oil pump? Is the timing chain beefier than the LS1?
10-04-2007, 12:55 AM #48
- May 2007
- Seattle
Jetstream Blue Metallic- 2008 Z06 Corvette
It does come with the LS6 oil pump, which is better, I replaced the chain with Comp cam's double roller, but it does have the same chain as the LS1. You'd be better off going with the LS2 chain.
Advice: Replace 1 or both CATS
By theblackesteyes in forum General HelpReplies: 7Last Post: 02-09-2014, 06:05 AM -
Question: port/polish and replace TB, advice?
By Wicked96Z in forum External EngineReplies: 3Last Post: 01-27-2009, 04:49 PM -
Question: Rebuild or replace steering?
By JoshieDoom in forum General HelpReplies: 10Last Post: 08-02-2008, 11:19 AM -
Rebuild it or replace it?
By Selah in forum DrivetrainReplies: 15Last Post: 08-31-2006, 06:27 PM -
Replace or rebuild???
By LS1Pwrd01SS in forum General HelpReplies: 14Last Post: 08-27-2006, 02:54 PM
