Results 1 to 11 of 11
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Rebuild or replace steering?
    Ive replaced both my outer tie rod ends but I still have a nasty pop sound when turning left to right. It does it the worst when the key is on, engine is off and you turn the wheel left to right. Its got play in it as well from this. I can get both inner tie rods and hope this cures it or should I break down and get a whole new assembly ?
    EDIT:I can get a brand new short rack for 360 bucks. Tie Rods another 68 bucks a peice.
    Bragg NC
    Met. Sunset Orange
    01 SS
    Your best bet is to have someone under the car while you turn the wheel from lock to lock to see if they can pin point where its poping from. Otherwise your just going to throw parts and money at the car hoping that it will fix it.
    J
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Good point. If you jack it up you should be able to narrow it down with a friend.
    Beaver Dam KY
    79 T/A -91 Firebird
    Its popping on the inside of the steering rack. Dead in the middle.
    TEXAS... U mad?
    Black / Stryker Blue
    2K WS.6/ 2K9 G8GT
    do it all...
    Beaver Dam KY
    79 T/A -91 Firebird
    I think im going to buy the center section and build it one piece at a time. Should be around 500ish after the aligment to get it all done. Might as well get a ws6 one as well with the cooler The thing falls apart at 150xxx on the dot.
    TEXAS... U mad?
    2K WS.6/ 2K9 G8GT
    SATX
    2000 Trans Am
    sounds like your U-joints. I when I have that problem (although its my diesel truck but its quite similar) I just re-tight them.
    Beaver Dam KY
    79 T/A -91 Firebird
    MOST DEFINATELY NOT the u-joints. You can pinpoint the sound exactly and its in the middle of the rack setup. Everything is very tight from the input shaft up.
    SATX
    2000 Trans Am
    well my truck might be simlilar, just offering some tips you dont have to be rude :P
    Beaver Dam KY
    79 T/A -91 Firebird
    Not being rude just stating for everyone its not that.
  1. Steering Box Rebuild - Steering You Straight
    Last Post: 05-25-2010, 03:40 PM
  2. Need to replace/rebuild LS1 99 WS6 Need Advice!!!
    By belairtx55 in forum Internal Engine
    Last Post: 10-04-2007, 12:55 AM
  3. Rebuild it or replace it?
    By Selah in forum Drivetrain
    Last Post: 08-31-2006, 06:27 PM
  4. Replace or rebuild???
    By LS1Pwrd01SS in forum General Help
    Last Post: 08-27-2006, 02:54 PM
  5. How difficult is it to replace the steering rack
    By LuS1fer in forum General Help
    Last Post: 09-12-2005, 11:45 PM
