Results 21 to 32 of 32
09-11-2009, 05:47 PM #21
09-11-2009, 08:00 PM #22
That seems more reasonable but I don't want to get into mail order stuff just for a bottle of fuel cleaner.
I'll have to check around the local boat stores and see if I can't find it around town. But it's lookin' more like sticking with Lucas is just better all around for me. I can grab that at just about any store in town.
09-11-2009, 10:05 PM #23
- Jun 2009
- Hollywood, Florida by way of Da' Burgh
Impulse Blurr- 2004 GTO
You don't necessarily have to use the Pennzoil full synthetic. I'm going with the Pennz cuz it says "Synthetic" on the bottle and that gets me excited. Any TCW3 rated oil will do. I pass about 5 places that probably stock it on my way to work (6 miles). Yes, I was rubbing it in with that last line.
09-12-2009, 04:43 AM #24
- Cedars, Pa
White- '02 Camaro SS
Goat-E
I just reread Sarge's post after reading what you stated and he says nothing about just [U]ANY[U] TCW3 oil, only Pennzoil Marine meeting the criteria set forth for their requirements. If you have been testing on your own and have verified results then please let us know, we want to hear. Otherwise blanket statements like the one above are detrimental.
I have added the link for Sarge's findings so you can see what I am referring to.
http://www.ls1.com/forums/showthread.php?t=91206
09-12-2009, 05:23 AM #25
TC-W3 rated oils have to meet a certain standard in order to attain that rating. It is by definition an ashless marine oil, however, its properties apparently lend itself to be utilized in our vehicles as an additive.
There is a lot of literature on this oil, plus certification lists that are accessible on-line: http://www.outboardmotoroilblog.com/...-does-it-test/ I simply purchase the Walmart brand TC-W3 at this time as it is really the only brand that is readily available in our area.
09-12-2009, 06:41 AM #26
09-12-2009, 07:57 AM #27
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
I'd like to know where to find it for under $10 a gallon like in sarge's threrad
09-12-2009, 11:43 AM #28
09-12-2009, 12:06 PM #29
- Cedars, Pa
"Pennzoil Marine® Full Synthetic 2-Cycle Oil provides protection for high horsepower applications that require approved NMMA TC-W3® oil."
"It is recommended for and meets the warranty requirements of Johnson/Evinrude, Mercury Marine, Yamaha, Suzuki, Force/US Marine, Mariner and others requiring NMMA TC-W3® oils."
Sir I suggest you reread, as I put forth in my previous post. These two sentences that I copied are from Sarge's post and are in fact, declared in the post, part of Pennzoil add copy. What they state is that the oil will work in that application and it meets warranty requirements of the oil specification.
"What we are trying to accomplish ( The deliverables)
We need to lubricate the fuel pump/seals/injectors.
We need to clean the fuel system and scavenge water that ethanol attracts.
We need a film of protection in our fuel system to stop corrosion.
We need a cleaner for our spark plugs/valves/combustion chambers.
We need to clean the ring packs
We need to leave a film on the cylinder walls to eliminate cold start metal wear.
This was my groups short list of deliverables. Of course we knew if we accomplished this list the car should A) Run Smoother B) Run more efficiently C) Parts will last longer i.e. fuel pumps/injectors etc. D) We should see more RWHP and MPG.
We did it. For pennies.
2 Stroke oil. Not just any two stroke oil But we needed the detergents etc. and found the perfect oil/add packs/viscosity in a marine 2 stroke oil you can get for under $10 bucks a gallon anywhere. We used Pennzoil Marine 2 stroke for our testing. Here is the "blurb" from Pennzoil....."
If you look in the paragraph above:
Where in Sarges post does it state that the TC-W3 specification is the main citeria?
09-12-2009, 01:01 PM #30
I ended up using seafoam and i noticed that it accelerated alot better and i got great gas mileage down here to FL, but for some reason my range started acting up (when i usually fill up it will be around 320)it started at 320 then went down to 310 and then up to 340. by the time i was down to half a tank (which is usually about 180 or so) the range was at 310. then when i filled back up it shot up to 520. the needle is still accurate though
09-13-2009, 03:21 AM #31
- Jun 2009
09-13-2009, 03:48 AM #32
I use "Gumout" complete fuel system cleaner twice a year. I do not know if it is doing anything, car ran fine before using, car runs fine after using.
SteveC
I'm sure he'll get the same treatment
By GTP231 in forum Political / Debate ForumReplies: 11Last Post: 01-22-2015, 06:35 PM -
Fuel Treatment- Is it worth it?
By bman149 in forum Domestics and ForeignsReplies: 0Last Post: 07-16-2011, 12:27 PM -
Lucas oil fuel treatment in LS1 engine?
By mammoth713 in forum General HelpReplies: 45Last Post: 01-10-2011, 04:43 PM -
Stabil and fuel treatment
By slikws6 in forum General HelpReplies: 7Last Post: 12-01-2008, 04:32 PM -
Best Tire Treatment?
By Waynestep in forum Showcar and DetailingReplies: 17Last Post: 04-13-2006, 02:04 AM
