Results 21 to 40 of 94
Thread: E-85 flex fuel who using it????
05-01-2006, 08:19 PM #21Originally Posted by ericwilloughby
05-02-2006, 09:07 AM #22Originally Posted by Liquifire
05-02-2006, 04:47 PM #23
- Apr 2006
- south chicago burbs
- 04 srt4 and 99 firebird
If that's what you think first you must step into the 21st century to realize why.
Everything with cars these days are computer controlled and the stoichiometric combustion of alcohol is lower. It requires more fuel since the hydrocarbon chain is smaller, meaning 14.7:1 of gas means everything is utilized but you need like 10:1 for alcohol. The alcohol has a chain of oxygen on it and it is more powerful so even though it looks like you would need 50% more fuel you only need about 15% more fuel and you can make a lot more power. Now with the computer, car manufacturers know that since it is higher octane they can spray less fuel while still supressing knock, lower emissions, and gain fuel economy.
Regular fuel
Bosch state (sic) that most spark ignition engines develop their maximum power at air/fuel ratios of 12.5:1 - 14:1, maximum fuel economy at 16.2:1 - 17.6:1, and good load transitions from about 11:1 - 12.5:1. However, in practical applications, engine air/fuel ratios at maximum power are often richer than the quoted 12.5:1, especially in forced induction engines where the excess fuel is used to cool combustion and so prevent detonation.
Source: http://www.autospeed.co.nz/cms/A_1595/article.html
Since ethanol is even higher octane you can lean it out more, by doing this you can achieve better fuel economy. To achieve even better fuel economy you can spray less fuel and retard timing a little. Now you have awesome fuel economy, excellent emissions, cheap long lasting gas, but all at the expense of power. This is why cars using E-85 might feel like they have less power than gas. A car tuned for ethanol though will have more power than one tuned for gas!
05-03-2006, 02:20 PM #24Originally Posted by NaztyZ28
I.E. I was trying to start a bon fire. All my gas cans have 93 octane in them. I ran out of 93 and had to use premixed 2 cycle. Used same amount of gas I always do. When I light the fire there is usually a small whooose so I always turn my head as I through the match. Good thing bacause that 2 cycle mix, having MUCH lower octane, went off like a bomb. The fire ball went past my body and all my neighbors came out wondering what the hell happened because there windows ratlled.
05-03-2006, 02:23 PM #25
You may already know that octane has nothing to do with the amount of power, BTU's, in gas. The higher the octane the more resistant to burning. If you dont have the heat or the timing I could easily see how it would run worse on higher octane.
05-03-2006, 02:32 PM #26
I thought alcohol burned best at 7 to 1. I'm almost sure of this. Alcohol is much less powerful than gas. The reason a flex fuel car that make 115 HP on gas makes 118 on alcohol is it burns twice as much fuel to do it.
05-03-2006, 02:45 PM #27
i was just told that GM is creating motors specifically designed for ethanol with a higher compression rate, so im assuming this makes up for the fuel economy?
05-07-2006, 09:24 AM #28
Nope! You'll get a little better than half the mileage and the fuel will cost about half what gas does. But the money stays in the U.S.
05-07-2006, 09:25 AM #29
GM and Ford have made these cars and engines for years for use in Brazil.
05-07-2006, 09:33 AM #30
A\F ratio for alcohol
On a K&N site that is selling air fuel ratio gauges.
http://www.knfilters.com/airfuelmonitors.htm
ECONOMY BEST ALL-AROUND POWER
Light 1 Light 2 Light 3 Light 4 Light 5 Light 6 Light 7 Light 8 Light 9 Light 10
Gasoline 17.1 16.0 15.1 14.7 14.7 14.7 14.7 14.0 13.2 12.1
Alcohol 7.6 7.1 6.7 6.5 6.5 6.5 6.5 6.1 5.8 5.3
Propane 17.9 16.8 15.9 15.6 15.6 15.6 15.6 15.0 14.0 13.0
05-07-2006, 01:11 PM #31
- Sep 2005
- chicago
yellow- 2002 collectors edition
I just used half and half last night, my wide band reading was about the same,just a little leaner than I like, around 12.6 at full open, its around 12.0 with gas only, but the scanmaster was around 800, the car ran great getting about 7 pounds, and no knock, it a great octane boster, and it sure beats paying 5 dollors a gallon for race fuel.
05-07-2006, 10:21 PM #32
Wow. That must mean that your PCM is reading the lean condition of the al use and compensating for it. WOW.
half and half?? what kind and % AL?
Whats? the scanmaster and 800 what??
05-08-2006, 08:48 AM #33
- Sep 2005
- chicago
05-08-2006, 10:44 AM #34
sorry if i sound like a , but don't our cars have some sort of reader to differentiate the air/fuel mixture under different octane levels? I remember reading in my manual, "premium is recommended, although you may use regular. with regular unleaded gas, your car may experience a power loss."
05-08-2006, 03:22 PM #35
I know half the answer to this.
There is no A\F ratio differance in relation to octane. Only type of fuel. AL, diesel, gas, propane. The optimum A\F for gas is 14.7 regardless of octane. As stated 10 posts back: octane has nothing to do with the amount of power, BTU's, in gas. The higher the octane the more resistant to burning.
The only way I know of that the car is determining what octane you are using is via the knock sensor. A retuner-programmer should answer this further.
05-08-2006, 03:23 PM #36Originally Posted by stage274
05-08-2006, 05:11 PM #37
- Apr 2006
05-08-2006, 10:01 PM #38
- Sep 2005
- chicago
Originally Posted by ericwilloughbyLast edited by stage274; 05-08-2006 at 10:04 PM.
05-09-2006, 04:51 AM #39
- May 2006
- Warren, MI
Red- 2001 Camaro SS
Hydrogen is not fuel, and never will be. It is an energy carrier, like electricity. You have to make it somehow (and electrolyis of water is the worst way, unless you have loads of surplus electricity, like maybe at a nuclear power plant during off-peak times). Whatever means you use to make it, it takes more energy to produce it than you can get back out of it. The most efficient way to make it right now is from chemically reforming methane. Which has the dreaded carbon in it anyway. Whatever way you make it, it's like carrying water in a leaky bucket. The best you can do is to move the pollution to someone else's back yard, and end up with terrible efficiency along the way. The 'hydrogen economy' is driven by tax dollars, going from you to the well connected politicians and those who play the game, counting on the fact that they don't teach science in high school any more. Anyone wanna buy a few shares in my hydrogen well?
Alcohol should be called Taxohol. Alcohol is a fuel, unlike hydrogen. That's because at its root, it gets its energy from the sun. But there are a few problems. The sun shines weakly, energy - wise. So it takes a lot of acres and a lot of time to get enough bio stuff to make very much alcohol. And it takes a bunch of energy to farm the stuff. A bunch more energy for fertilizer. A bunch more energy to brew the soup. And a tremendous amount of energy to distill it. By the time you get done with an honest accounting of the energy, land use, time, and labor it takes to make the stuff, it is dismal on energy return and cost. The only way the propaganda shows like that special on Brazil can tout the benefits of alcohol as a fuel is if they count on the fact that nobody is going to bother to add up all the costs. Ethanol is being promoted with gigantic subsidies of tax dollars in the U.S. With current practices, if you add it all up, it is taking about 7 times as much energy to produce a gallon of ethanol than you get back by burning it.
The short version is, if there were some magical way to get energy that is cheaper and cleaner, there would be a bunch of people lining up to make their millions on it. Unfortunately, oil comes out of the ground almost free, takes very little conversion to make it very portable and pretty clean, and it carries a tremendous amount of energy in the products gotten from it. Give up any of those advantages and you have to make it back up somewhere else. There is no free lunch when it comes to energy and thermodynamics, unless you own an oil well or a gas well.
Be aware that your energy consumption has a one to one relationship to your standard of living. If the cost of energy goes up, your standard of living goes down. It takes energy to make any and everything, so increased cost of energy raises the cost of all goods you might want to buy. And if you get restricted in the amount of energy you can buy, then your standard of living will be drastically reduced. The history of the advance of man is a history of more concentrated, safer, and above all less expensive energy, and devices to use that energy. Our econcomy depends on it, and your livelihood depends on it. Your very life depends on it, at least the first ten percent of what you use.
How many people with normal jobs in Brazil can afford to drive a Camaro SS? What is the standard of living there? How does interference in the economy by the government affect the prices charged for their ethanol? Are there high taxes on other sectors of the economy being used to put huge subsidies to help out their ethanol program? Are the ethanol plants and the farms privately owned? Do the farm laborers have cars too? If the crop isn't subsidized, can the farmers make as much per acre growing sugar cane for ethanol as they could growing any other crop for human consumption?
The problem the greenies have with oil is that it gives the vulgar peasants access to a much higher standard of living than they think they should have, and it makes way too many millionaires, building cars and other products for them. They look with envy at Europe, where the socialist governments tax energy so high that people ride bicycles to work, and build cities to exclude cars. Just remember that their aim and their strategy is deprivation of energy to the common man. They especially hate the idea of kids having 400 horsepower cars.
The way they hope to rule us is to get the ignorant masses to believe a pack of lies about global warming. This will give them the excuse for energy rationing = deprivation. Of course, this megalomaniacal scheme will probably never come to full fruition. But along the way, there are huge amounts of money to be skimmed off the gullible taxpayers, with corporations and scientists lining up to tell the Big Lies to get government handouts for research, propaganda, and subsidies. Whoever doesn't repeat the lie will be left out in the cold. The fashionable ones will be made rich off tax dollars. Of course, business as usual will continue, but it will be punitively taxed and roundly denounced. Third world nations will jump on the bandwagon; they love any excuse to keep the masses under their thumb. A people with a miserable standard of living and no access to energy lacks the time and surpluses to resist when they are living hand to mouth. A most excellent scheme to perpetuate their power structure.
Anyone who likes their muscle cars should educate themselves about the physics of energy so that they can expose the lies and hopefully work to defend the freedom and economy that makes muscle cars available to people that want them. Otherwise, the argument will be about whether you need them. And the answer will be given by somebody else.
--NinerSevenTango--
End Of Rant, Thanks for listening.Last edited by NinerSevenTango; 05-09-2006 at 04:57 AM.
05-09-2006, 11:06 AM #40
- Sep 2005
- chicago
Originally Posted by NinerSevenTango
Question: 5.3 flex fuel mods
By jimmyz454 in forum General HelpReplies: 7Last Post: 05-27-2014, 02:20 PM -
2009 Ford Flex - Hot Rod Ford Flex
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 08-10-2009, 10:00 PM -
T-top flex!!!
By JoshieDoom in forum Firebird / WS6Replies: 23Last Post: 09-30-2008, 09:56 AM -
Need Fuel Pressure specs for an '02 5.3 Flex Fuel
By Fortune50 in forum GM TrucksReplies: 1Last Post: 09-04-2007, 08:18 AM -
GM Flex Fuel question
By Nastyfoot in forum General HelpReplies: 5Last Post: 08-18-2006, 04:31 AM
