Results 21 to 29 of 29
Thread: Best Oil, Filter, and Diff Fluid
10-06-2008, 04:45 AM #21
UOA comparison…
You might not get the best results comparing two different oils with back-to-back UOAs. Reason being is that you are not always able to get every last drop of old oil out of the oil sump, so there will be some cross contamination and mixing of the two different additive packages from two different formulations. If you can, try and hold off on the Amsoil UOA until a second oil change interval. Then you will have a more balanced chemistry inside your engine and end up with a more meaningful comparison.
CompSyn
10-06-2008, 06:18 AM #22
10-07-2008, 06:41 AM #23
Modified Conditions...
Agreed! Many of the enthusiasts here on LS1.com fit the criteria listed below.
"Engines operating under modified conditions are excluded from extended drain recommendations. Examples include the use of performance computer chips; non-OEM approved exhaust, fuel or air induction systems; and the use of fuels other than those recommended for normal operation by the manufacturers." - AMSOIL INC.
10-07-2008, 07:41 AM #24
good info in this thread! just wat i was looking for
10-07-2008, 04:59 PM #25
Royal purple all the way!!! And ive heard it even gives u a couple more horses ya its a little expensive but its totaly worth it. Use the motor oil and the tranny fluid u wont be disappointed.
10-07-2008, 07:38 PM #26
- Apr 2006
- Chowchilla CA
White- 2001 Z28
Royal Ripoff!
This UOA is RP 5/30 vs Mobil 1 5/30. With RP more shear and more wear. But don't think I am endorsing Mobil 1. PP 10/30 is better oil for less money.
Now lets see how Amsoil stacks up!Last edited by lonewolf37; 12-25-2008 at 08:46 PM.
10-08-2008, 04:35 AM #27
10-08-2008, 04:36 AM #28
10-08-2008, 11:02 AM #29
Amsoil race oil is the best .acdelco pf46 oil filter
GM Synchromesh for the t56
80 w 90 gear oil (regular ) for the dff
Diff Fluid
By Sarge in forum GTOReplies: 42Last Post: 06-10-2011, 08:38 PM -
Changing diff fluid..
By ls1fan74 in forum GTOReplies: 37Last Post: 09-03-2009, 09:10 AM -
diff. fluid/ additive
By imflyn in forum DrivetrainReplies: 5Last Post: 11-02-2006, 10:54 AM -
best diff fluid? good diff cover?
By ErikElvis in forum Camaro / SSReplies: 3Last Post: 03-23-2006, 08:49 PM -
What kind of Diff Fluid you running?
By Sarge in forum GTOReplies: 10Last Post: 10-14-2005, 11:20 AM
