Results 1 to 11 of 11
Thread: Service Engine Soon Codes
01-08-2007, 11:43 AM #1Junior Member
- Aug 2006
- Florida
Chamelion- 1998 Trans Am Convertible
Recently, my 98 ws6 started showing the check engine soon light. I had the codes read at the local store and they are p0442 Evap Emission Control System Leak (small). and p1415 Manufacturer Control Auxiliary Emission Controls. I do not know where to start to look for these leaks. Any suggestions? Thanks.
01-08-2007, 11:46 AM #2Will Rev for Beer
- Panama City Beach, Florida
Yes.- bunch of them
Start with tightening the gas cap.
01-08-2007, 11:53 AM #3Junior Member
- Aug 2006
- Florida
I have already tightened the cap and i am on my second tank of gas now. The car runs fine, but the light still appears. I did not reset the computer, would you suggest i do that first?
01-08-2007, 11:56 AM #4Senior Member
- Jul 2005
- Jacksonville, FL
P1415 is probably just a clogged drivers side air check valve, cheap and easy to replace yourself. I had P1416 for the passenger side valve. Usually a gas cap will throw P0440, but check the gasket and make sure it's tight anyway. Friend of mine had P0442 and had to have a shop pressurize the EVAP system with smoke to find his, hopefully you won't have to do that.
01-08-2007, 04:02 PM #5Junior Member
- Aug 2006
- Florida
When they ran the smoke test, what wound up being the problem? Was it still emissions related? Also, i will replace the drivers side air check valve. I am not sure exactly what the part is, can you explain it to me? I appreciate your help.
01-08-2007, 04:14 PM #6
01-08-2007, 04:26 PM #7Senior Member
- Jul 2005
- Jacksonville, FL
The air check valve is the black, disc shaped valve between the metal air pipe coming of the header above the #5 coil pack, then connects with a clamp to the air hose on the back side. Just remove the clamp/hose, then use two wrenches to unscrew it from the pipe - one to keep the pipe steady and the other to unscrew it. PN on mine was 12565503, but doublecheck cause sometimes '98's are different.
Can't tell you exactly where his leak was, but it was back near the gas tank - and a little expoy sealed it. Also, he had his fuel pump replaced a few months earlier so that might have had something to do with it. Might not be the same problem on your car.
I'd replace the air check valve, clear the codes - then see if P0442 returns.
01-10-2007, 04:53 PM #8Junior Member
- Aug 2006
- Florida
Thanks a lot for your help. It is greatly appreciated.
09-20-2009, 08:25 PM #9Junior Member
- Nov 2007
- Alamogordo, NM
Navy Blue Metallic- 2002 Camaro SS
P0442
I have the P0442 code as well, and my gas cap seal is kinda of worn with cracks. Did replaceing the cap do it for you and did you reset the computer?
11-05-2009, 04:24 AM #10Junior Member
- Aug 2006
- Florida
I never did fix the problem. I am finally going to go to the dealer this week and get a new cap. I figure at 12 years old, the car is due for a new cap anyway. I will let you know if it works.
11-17-2009, 06:24 PM #11Junior Member
- Nov 2007
- Alamogordo, NM
I bought a replacement cap at AutoZone and the Service Engine Soon light went out about a week later.
Service Engine Soon
By 1 RedHot TransAm in forum Firebird / WS6Replies: 5Last Post: 11-14-2008, 08:47 AM -
Help: Service Engine Soon Light.engine Code No.7missfire
By josh68 in forum General HelpReplies: 10Last Post: 07-16-2008, 08:47 AM -
Service Engine Soon
By 2001bird in forum General HelpReplies: 2Last Post: 10-18-2006, 03:40 PM -
Quick Question about Codes on the Service Tag ID???
By 98LSGUN in forum Camaro / SSReplies: 4Last Post: 09-07-2006, 10:10 AM -
Washed engine with hose now Service engine soon light is on help?
By JehalinTA in forum General HelpReplies: 14Last Post: 03-30-2006, 12:59 PM
