Results 1 to 20 of 40
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    what 15" racing wheel will fit?
    running a 15" wheel in the back of the fbody
    15" x 7" w/4.5" backspacing
    15" x 8" w/5.5" backspacing
    15" x 10" w/7.5" backspacing
    it will require a large amount of grinding of the rear calipers to clear the wheel. here's pics of what i had to do to mine. scroll to the bottom.
    http://www.stealthram.com/wheels.htm
    one thing to remember, if you do your grinding with half worn brake pads, when it comes time to replace them, the wheels may hit again. the thicker the brake pads, the further outward the caliper moves.
    i encourage others to show what they put on and needed to do to get them to fit.
    🤔 11s. blackbirdbrain89's Avatar
    hagerstown, mercersburg
    black trans am
    2000
    why dont u add what 16 inch wheels and 17 inch racing wheels will fit and aslo add the bolt pattern while ur at it?
    orlando, fl
    2014 camaro 2ss/rs
    follow the same guidelines.
    after seeing about 10 threads in one week about what 15" wheel can i use, i made this.
    the bolt pattern is 5 x 4.75"
    Junior Member z06this's Avatar
    May 2008
    Minnesota
    98 Camaro z28
    Anyone have experience running Center Line Convo Pro's up front and in back?
    I'm interested in 15x7 with 5" backspace (+25 offset) up front and 15x9 with 6 1/2" backspace (+32 offset) in back. Any clearance issues with brakes, suspension or fenders?
    May 2008
    Minnesota
    98 Camaro z28
    Forgot to mention tire size.. would be 225/60r15 up front and 275/50r15 out back. Thanks.
    orlando, fl
    2014 camaro 2ss/rs
    the last thing i remember reading was the convo pros fit out back with the same amount of grinding. i haven't heard of anyone fitting more than the 15 x 4 wheel for the front. for giggles, i tried putting a 15 x 7 with 4.5" BS on the front of my car a guy was selling. it would not clear the front calipers without a decent sized spacer.
    May 2008
    Minnesota
    98 Camaro z28
    So 15s just don't fit without grinding. Glad I got your input before I spent the money. Back to the drawing board. Know any companies that make light 16/17" wheels for street/strip apps besides billet specialties and center line? Know any aftermarket drag brake kits that would clear the 15s? Not really feeling the whole grinding thing. Thanks.
    Quote Originally Posted by z06this View Post
    Bogarts are supposed to. No experience though.
    The new Greg Welds are supposed to as well...BUT they are still developing them.
    May 2008
    Minnesota
    98 Camaro z28
    Does that mean that you would have to run a smaller backspace for them to fit and then they would stick way out? So have you heard of those bogarts fitting at all?
    May 2008
    Minnesota
    98 Camaro z28
    BTW, the centerline 15x7 has a 3 3/8" BS. think that would fit?
    May 2008
    Minnesota
    98 Camaro z28
    I read the Greg Welds are out now. I emailed them to see whats up. Thanks for the heads up on those Luos!
    Last I read (about a week ago) they had the skinnies done, but were still working on the design on the rears.
    Apparently...according to a helper in the design...the rears will not be 'grinding free' for another 30 days or so.
    Posted 'elsewhere' yesterday.
    Some of the sizes are released. Just not the perfect fitting ones I guess.
    orlando, fl
    2014 camaro 2ss/rs
    from what i know, anything other than the 15 x 4 will not clear. and you'll need a 5/16" spacer for the front with skinnies.
    orlando, fl
    2014 camaro 2ss/rs
    you can downgrade to the rear LT1 brakes.
    black trans am
    2000
    i emaled greg weld wheels and they told me that they are coming out with a 15X10 with a 7.5 back space just for f bodys. not out yet but coming leate this summer and that they will be the star not the lights
    May 2008
    Minnesota
    98 Camaro z28
    I'm going with the 15x10/7.5 and the 17x8/5.5 greg weld stars. Hope they come out soon. Wanted to go with skinnies in the front but I can't stand the idea of having spacers. I'm not going to gain much aero with the skinnies with how low the front end will be anyways.
    Junior Member HELLISSH's Avatar
    Aug 2008
    SOUTH TEXAS
    BLACK
    2001 SS
    Thumbs up
    Ya 15x10 7/12 Back Space And 27in 10.5 Should Fit Just Right!!
    More weight than aero.
    Plus, the less on the pavement, the less resistance.
    JMAC Racing WS6ICK's Avatar
    Kentucky
    2000 Trans Am WS6 LS6
    2006 GTO LS2
    Whats the advantage of running 15" instead of 17"? Do you have to grind the fronts as well? What backspacing should the fronts be?
    2010 Camaro
    2006 GTO, LS2, 1 of 475
    2009 Chevy Silverado
    Senior Member Bottesini's Avatar
    Denton, Texas soon Lafayette, Louisiana
    Blue
    2002 Z28 Camaro M6
    Quote Originally Posted by WS6ICK View Post
    There are a few advantages.
    1. Less weight
    2. More sidewall to wrinkle
    3. Seems to be the size that most of the stickiest tires are made to fit.
  1. Wanted: 98-02 OEM 16" wheel "ABS" black background center caps
    By JayTA98 in forum Parts Wanted / Trade
    Last Post: 11-05-2012, 12:40 PM
  2. Ruff racing r280 18"chrome wheel info 18"
    By rstewart in forum Wheels and Tires
    Last Post: 01-20-2009, 12:57 PM
  3. FS. "newish" Spec stage 5 racing clutch.
    By sscrazy in forum Parts For Sale / Trade
    Last Post: 12-19-2007, 04:10 PM
  4. FS: Thunder Racing TR227/224 "reverse split" camshaft
    By TwistedSS in forum Parts For Sale / Trade
    Last Post: 06-07-2007, 05:43 PM
  5. "Chevy Racing" jackets.. Officially Licensed GM products!!!
    By Style in forum General Classifieds
    Last Post: 01-17-2006, 10:22 AM
