Results 1 to 19 of 19
Thread: Koni Lower perch location?
02-20-2008, 10:35 AM #1
- Pittsburgh, PA
i bought a set of used koni's and don't know if they were set lower or standard ... how does one do/undo that? I want mine to be "unlowered" as i have Prokit springs on my car allready
02-20-2008, 10:40 AM #2
- Sep 2005
- rochester,ny
pewter- 2001 z28 lingenfelter 383
02-20-2008, 03:42 PM #3
You should be able to see both perch locations Jay.
Turn your wheels and take a look, but since you have lowering springs they are not set on the lower perch.
At least they should'nt...
02-20-2008, 03:58 PM #4
- Pittsburgh, PA
ohhhhhhh ok...they way i've always heard [read] people said it was actually on the shock...thanks for clearifying.
02-20-2008, 06:42 PM #5
ahh the lower perch is located in the shock that is why you can only do this with koni SA shocks.
You cannot really see it in this picture:
But no one uses the lower perch unless they are using stock springs and are trying to lower the car (get about 3/4")
02-21-2008, 05:53 AM #6
- Pittsburgh, PA
SOW, you just contradicted yourself...is it on the shock or not???
02-21-2008, 06:22 AM #7
Yes both perches are located on the shock body.
How did I contradict myself?
Gonna need a quote on this.....
02-21-2008, 09:44 AM #8
- Pittsburgh, PA
sorry, bro! it just seemed like you were agreeing with Tonyjnjz where he said they are on the car.
OK, so WHERE on the shock body are the locations? I need to make sure mine is at the correct length
02-21-2008, 10:33 AM #9
- Sep 2005
- rochester,ny
02-21-2008, 11:22 AM #10
- Oct 2005
- CT
White Liquid Silver- 2000 Camaro SS/ 02 YZF-R1
And I was going to ask you for install help...pfft...LOL
02-21-2008, 11:23 AM #11
- Oct 2005
- CT
Hey SOW did your old shock explode in the wheel well or is that just wet?
02-21-2008, 03:21 PM #12
Just run your hand under the perch and you will feel the ridge used for the lower perch location. If you don't that means the previous owner used the lower one.
But I seen your pictures and it is not THAT low...
That is PB blaster over spray used to soak the bolts over night prior to taking on any bolt in the under carriage. They are a bitch to break loose esp. fasteners under the car!!!
Soak them for at least 24 hours (more if you can) prior to tackling the install Joe.
02-21-2008, 04:44 PM #13
- Oct 2005
- CT
I plan on installing a set of Koni's and Strano springs by spring time, thanks for the heads up on letting them soak...my car is a garage queen that has never seen rain or driven on salted or sanded roads so hopefully it will go pretty well. Nice set up by the way, I'm liking the braided brake line too
02-21-2008, 05:34 PM #14
02-21-2008, 07:19 PM #15
- Jun 2002
- Montreal, CANADA
the perch is that plate that holds the spring.
Under it is a C-clip in a small indented spot on the shock.
There are 2 of those indented spots that accepts the C-clip... hence having 2 perch locationsEugenio_SS
02-21-2008, 09:15 PM #162002 Artic White SS 35th Wheels|Full Hotchkis Suspension|Koni SA|Magnaflow CME|SLP lid|www.fquick.com/The_Guz
02-22-2008, 04:28 AM #17
03-07-2008, 04:32 PM #18
03-08-2008, 09:30 PM #19
- Jun 2002
- Montreal, CANADA
SA have them... not DA.
Question: Getting rear springs off the perch...
By bhunter0830 in forum Suspension and HandlingReplies: 10Last Post: 04-08-2013, 05:53 PM -
Help: spring perch
By egod in forum Suspension and HandlingReplies: 3Last Post: 04-14-2011, 08:28 AM -
Help: Spring Perch
By FMBL in forum Suspension and HandlingReplies: 5Last Post: 03-26-2011, 03:09 PM -
Question: Lower Perch Lowering Mod
By n.m.racer in forum Suspension and HandlingReplies: 4Last Post: 03-24-2009, 11:03 AM -
WTB: front strut upper spring perch
By up2nuthingud in forum Parts Wanted / TradeReplies: 0Last Post: 08-26-2007, 04:14 PM
