    Albany NY
    1999 Firebird Trans Am
    How To Remove Door Panel Lettering
    What is the best way to remove these letters and will the finish under the letters be smooth...I would like to put a vinyl pinstripe throught that area
    Member Mike's TA's Avatar
    Austin, TX
    99 Trans Am(sold)
    Use either dental floss or fishing line and a hair dryer/heat gun.
    Heat it up a little then run the line behind it to cut the mounting tape. Rub the leftovers off with your fingers then use either goo gone, lighter fluid, or WD40 to remove the remaining sticky crap. I would recommend goo gone because it's gentler. But others have said the other two work fine.
    Cleaner wax, polish, and wax the area and you should be done.
    I would also recommend removing the door ding trim. I took mine off last weekend and I think it looks awesome.
    Albany NY
    Thank You Mike
    Austin, TX
    99 Trans Am(sold)
    Everything turn out ok?
    Albany NY
    Been busy...Will try to get to it this weekend..Will let you know
    Austin, TX
    99 Trans Am(sold)
    Cool. Post up some pics of your stripes when done.
  1. remove door panel
    By FMR_TransAm in forum General Help
    Last Post: 12-22-2011, 10:56 PM
  2. How to remove door panel w/ roll up windows??
    By 5abivt in forum General Help
    Last Post: 05-22-2009, 08:05 AM
  3. Firebird Door Panel Crack Repair - Door Panel Pandemic
    Last Post: 10-18-2007, 10:50 AM
  4. Door Panel Lettering
    By Mike's TA in forum Appearance Section
    Last Post: 10-05-2007, 09:23 AM
  5. Door Panel Lettering
    By Mike's TA in forum Firebird / WS6
    Last Post: 10-01-2007, 06:06 PM
