Results 1 to 15 of 15
    Impounded LS1 Trans am's Avatar
    Indiana
    blue
    97 LT1 trans am
    SES light on and code p102
    What would be wrong with my car possibly if I'm thowing the p102 or something like that code, It said something like Mass Air Flow: Low Voltage or something like that. What would cause that? I was thinking it could be my alternator, because when I start my car my tach and speedo go all the way up and down real slow and also it resets my trip, Any ideas?
    Senior Member
    Jacksonville, FL
    P0102? See www.gearchatter.com/viewtopic8916.php
    The gauge sweep/trip resetting to zero is from low battery voltage on the '99 cars. Here's the TSB on it: http://home.earthlink.net/~cetera/pics/aug99tsb.jpg
    Member 89LX's Avatar
    East Coast North Carolina
    Navy
    2000 Z28 M6
    Hot Wires
    2001NBMZ28 has your information in his link. It is as stated in the Service Manual. I noticed you ported your Maf. Make sure you didn't damage the hot wires. They keep a fixed temperature above ambient temperature.
    2000 Z28 M6, SLP Lid, SLP Bellows, SLP UD,
    P&P Maf, TB By-Pass, PS Shorties, LS6 Intake, FAST 78mm TB, Hooker CB, Hurst Billet, Front Tower Brace, small 218/218....527/527....114 cam.
    337rwhp/348rwtq
    Indiana
    blue
    97 LT1 trans am
    It was working and then I just had the voltage regulator replaced on the alternator, that's why I think it's the alternator messing with my voltage. It wasn't throwing this code until after the alternator was fixed. I'm about to go to o'reilys and get a new one with a lifetime warranty for $108 before it messes up something.
    Custom Built Rock Crawler rustynuts's Avatar
    Sacramento
    Quote Originally Posted by LS1 Trans am View Post
    when i can expect the $ that is owed for you know what?
    Indiana
    blue
    97 LT1 trans am
    Ran the tests off that website provided (although all I have is a test light and a ohm meter) and I had 5 volts between the signal and a ground and had the test light go off when I tested the ignition+ to the ground and then I found the engine sensor fuse was blown. So I replaced the fuse and went for a ride and the service engine light never went off, then when I got back I found the fuse was blown again. Any ideas?
    Navy
    2000 Z28 M6
    Again....did you check your wires in the MAF for damage or trash?
    Indiana
    blue
    97 LT1 trans am
    Talking about taking the maf apart or the 3 wires that are in the opening? Those wires arn't broken. Anything else? What about my alternator, it never hummed when I just turn my key on.. Maybe it's doing something crazy? Like to much voltage or not enough.
    Sacramento
    Quote Originally Posted by rustynuts View Post
    Indiana
    blue
    97 LT1 trans am
    Anything else on the MAF?
    Sacramento
    IT'S PROBABLY YOUR CARS CONCIOUS TRYING TO TELL YOU TO STOP RIPPING PEOPLE OFF!!!!!!!!! YOU'RE A REGULAR GENIOUS AREN'T YOU?????
    BEWARE OF LS1 TRANS AM. HE SCREWED ME OVER, DON'T LET HIM SCREW YOU OVER.
    READ ALL ABOUT HIM HERE
    http://www.ls1.com/forums/showthread...871#post766871
    San Diego
    2002 T/A
    Sold!!
    thanks robert
    I like how friendly you were back in December. j/k.
    Quote Originally Posted by LS1_TA_2002 View Post
    I would maybe consider making this right with him. Think about how you would feel if someone sold you a part without telling you there was something wrong with it. Just ain't right.
    Marylandistan
    2001 Trans Am (sold)
    Ditto.
    I Love High-Explosives! TheChad1371's Avatar
    Slatington, PA
    2000 Trans Am WS.6
    very shady business...
  1. p0410 code and no ses light?
    By Ortiz11b in forum General Help
    Last Post: 09-16-2011, 06:14 PM
  2. ses light came on, come in to help with code
    By krese in forum General Help
    Last Post: 04-28-2008, 11:47 AM
  3. SES light, A.I.R. code?
    By ArcticZ06 in forum General Help
    Last Post: 09-29-2007, 08:46 PM
  4. SES light.. wuts the code mean
    By rajiv1998 in forum Firebird / WS6
    Last Post: 05-01-2007, 06:00 PM
  5. SES Light Code# 1133
    By stevegrizzle in forum General Help
    Last Post: 10-26-2006, 11:12 PM
