Results 1 to 20 of 106
12-31-2006, 01:50 PM #1
Fix Your Passenger Window Motor!!!
Hoping to get a good number of install responces in this tread!
Anyone on this site successfully installed and currently enjoying this fix?
Pro's?
Cons?
Got passenger window problems?
http://www.autotrix.net
**Window Express Down Modules now availible**
http://www.autotrix.net/products.html
01-09-2007, 07:36 PM #2
01-17-2007, 02:03 PM #3
01-24-2007, 07:43 PM #4
Has anyone from this board purchased our window fix?
01-24-2007, 10:13 PM #5
- Nov 2006
- Earth
Don't give up on us. I have to fix my ps window and would like to buy the kit. I just need the time to get at it and some decent weather. I'm into other thing$ with the car but the window fix is important on the list.
01-25-2007, 11:03 PM #6
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
wow, looks promising. wonder if it will work on my ride. my pass side is going slower and slower and doesnt go all the way up in one shot. why is it only the pass. side?
01-27-2007, 09:00 AM #7
We currently only offer the passenger side fix. We are currently working on a drivers side remedy, passenger express down and the blinker kit.
There is a lot to be found on tech about us, but not alot of noise here.....
Here is a link that should answer any or all questions about us and our current product.
http://www.ls1tech.com/forums/showthread.php?t=609435
Here is a link to the blinker kit vote we had going on
http://www.ls1.com/forums/showthread.php?t=38069
Thanks for the interest in our new company!
02-18-2007, 08:06 PM #8
08-06-2007, 06:14 PM #9
- May 2007
- Cedar Park, TX
Black- 1999 WS6 Formula
Installed Window Fix. I have an install suggestion
Hello autotrix,
I installed the window motor fix when I replaced both of the window motors in my 99 Firebird. It works great. There is no more slowing down when using both windows at the same time.
One thing... I was not able to find a good way to fit the wires and two relays in the room under the window/lock controls in the arm rest, so I decided to route the wires back through the rubber tube between the door and the cab, and stash the relays in the room behind the kick panel assembly. It does require that you extend the D and the E wires from the window switch, and that you route them through the rubber tube, along with the wires to the motor, but I believe it is worth it. It is a lot cleaner in my opinion, with less clutter in the door arm rest.
Thanks for a great product.
08-06-2007, 06:39 PM #10
Yeah if you dont trim the relay connectors you will run out of room....either way it is a little of a tight spot, but is very possible!
Thanks for the great post up!
08-07-2007, 04:02 AM #11
I installed the window fix kit, the only hard part is putting the stupid door back together and getting the pcm out/in!!!
Now my passenger side window with OEM motor and your kit goes up faster than the drivers side window w/a new motor---Can you fix that too?
08-07-2007, 12:59 PM #12
Well I cant say for sure but when we release the drivers side fix (along with an express down module) it should allow the drivers side to keep up with an autotrix passenger side equipped motor.
Thanks for the post!
08-09-2007, 04:32 PM #13
- Dec 2005
- Huntington Beach, California
navy blue metallic- 2001 trans am
I istalled the kit in about an hour and a half and am soooo glad I did. Window seals tighter so no wind noise and cant beat the price. Somebody needs to figure out the driver side though people!!
08-10-2007, 06:28 AM #14
Thats great to hear, thanks for the post!
The drivers side remedy is coming very soon, accually we our testing two more prototypes today. Thanks for the interest, keep an eye out!
08-10-2007, 06:37 AM #15
- May 2007
- Davenport, Iowa
Bright Red- 1999 Trans Am Ws6
My works fine, just wondering, why did you choose relays bigger than the fuse? I believe it is 30 or 35 and u went with a 40/60 relay.
08-14-2007, 02:52 PM #16
- Tulsa,OK
Quick Silver- 2002 Z06
08-17-2007, 04:35 PM #17
- Jul 2007
- Florida
Pewter- 2001 Trans Am
window trix
I installed the fix and still had the same problem as before. Passenger window still opens and closes for awhile and then slows down and eventually just stops working. Give the window alittle time and goes up alittle at a time. Kept doing the same thing it was doing without the autotrix. Finally I removed the autotrix setup and experianced the same. Altogether I didnt see a change in the setup. Back to square 1 . Anyone know of a good reliable window motor for a TA 2001 non ws6. Any help is appeciated.
08-17-2007, 06:26 PM #18
- Dec 2005
dude, that is just your window motor going out, Ebay has them for 25.00 or so but leave the kit on cause with a good motor that window will FLY. trust me.
08-17-2007, 06:43 PM #19
- Apr 2006
- Indianapolis, IN
All Black- 83, 87, 02 All WS6 T/As
Hows the passenget express down coming? I'd like to get the kit and the pass express down when its available.
-Geno
1983 Black WS6 "WindCharger"
1987 Black WS6 "WS87"
Sold the other four f-bodies
08-18-2007, 08:29 AM #20
Funny you ask, I am going to be testing 3 different modules this afternoon. We are tring to work out all of the bugs for this one to ensure a quality product. This will also work as a replacement for the drivers side module and will allow less of a voltage drop to the drivers side window. We have been testing different methods for some time now and the final product is very close!
autotrix passenger window fix
By WS6S in forum Parts ReviewReplies: 17Last Post: 03-02-2016, 12:40 PM -
Passenger side window
By SS Camaro UK in forum General HelpReplies: 12Last Post: 01-15-2013, 06:54 AM -
Passenger Window won't work
By kempfer99ta in forum Firebird / WS6Replies: 15Last Post: 10-02-2009, 01:54 PM -
passenger side power window motor
By bcphilly01z28 in forum General HelpReplies: 3Last Post: 05-31-2007, 06:21 PM -
By mitch98ss in forum Parts Wanted / TradeReplies: 0Last Post: 09-19-2006, 06:53 PM
