Thread: Is It worth Building LSX???
11-25-2019, 12:59 PM #1
- Nov 2019
- Speed
- 1987 Monte Carlo SS
Greetings everyone, New to the forum but not new to the field. Have been reading and learning from this forum for years yet never became an active member. As my first post i wanted to ask is it worth building a motor for a street ls swap anymore??? especially with crate engines almost in turn key configuration such as BluePrint Engines Pro Series Chevy LS 376 CID 530hp going for little as $6800? Im building a Street car from the ground up and im at this cross road. The way i see it if i get an used engine from a salvage yard such as LQK, a decent LQ9 or LQ4 would cost $1500 Plus the core which i don't have. That would require machine work and at the minimum in my area just to look it over, hone the cylinders, piston rings and bearing that's gonna cost around $2000. Cam, valve springs and lifters $1000. Ls6 intake with Injectors and throttle body $1000. Just those items there would put me at $5500..... and that wouldn't make anywhere close to 530hp. with no warranty or guarantee. Then there's always the option of just camming a salvage yard motor and shoving it in the car..... what are you guys recommendations???? what would you do if you had to start fresh. This build is for a 87 Monte Carlo SS street car. Thanks in advance
11-26-2019, 07:27 AM #2
Umm those prices are awful high....
That $1500 must be for long block with ecm and wire harness. If you need all that then do so, cause trying to source one after is a PITA and at premium. In reality you just need a short block if doing an all out rebuilt and going to swap out pretty much everything.
I'll show you what I paid for my 403ci. But I did all of the assembly and installing it in my car.
99' LQ4 Short Block $250 - It was hydrolock and didn't pay a core charge either.
FAST 102 Intake $950
Polluter Stg3 cam - $375
243 Heads (Used) - $400
Melling 10296 Oil Pump $120
LS2 Timing Chain - $75
LS3 Injectors (Used) $350 + $50 to have them bench tested and serviced.
K1 Forged 4" Crank - $950 - This was a requirement for me because my crank was wiped out. If you get a good block with internals you may not need to get a new crank unless you go stroker route.
SCAT Forged I Beam Rods - $395
DSS Pistons - $425
Gaskets $250
King Bearings Main $200, Rod $130 These are top end bearings so there are lower price bearings.
Rings - $150
Optional
ARP Main Bolts - $325
ARP Head Studs $275
Trunion Rocker Arm upgrade - $120
Aftermarket Heads - $2500 (in the future) - I'm looking at some TrickFlow heads and a new cam that will be a better fit for my 403. When I originally was parts sourcing I had intended for a stock rebuild but after my crank was wiped I changed direction and went with a stroker. Glad I did so, now I have a solid foundation that I can build on.
Machine Work
Block bored 0.005", check cam line, and surface the head area for flatness - $230
Heads - (Head Job) Install new guides, lap the valves, install my new springs - $100 for both heads, not each.
Tuning $550, but it actually cost more because I had to pay for 2 sessions that ended up not being tuned because of mechanical issues discovered. My intake wasn't fully sealed and we couldn't figure out why we had a vacuum leak until I had to relocate the map sensor because I broke it. Turned out the back bolts on the intake needed to be locktite and ended up falling of and causing the vacuum leak.
Now if I would have had them put it all together it would have been $500 for labor.
Now having a turnkey built crate motor with I hope a warranty even limited could be very worth the money. Especially if you haven't built one before, or have the tools and skill set to do so. I took my time and have the tools and even had most of the skill set to try it. I took it on as a learning project and enjoyed getting my hands on it.
Another member here had Tick Performance build his engine and he can give you the specs and costs on his. I'll tag him to see if he'll post on here so you have a perspective on that side of a build.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
00 FB Vert - Stock
11-26-2019, 07:51 AM #3
- Apr 2010
- Alabama
Mine was a bit more expensive but mine was a larger stroker motor but honestly not that pricey for what it is, a max effort NA motor but it has much higher quality parts than one of those turn key motors from gm you are talking about. When I get home tonight I'll post prices so you can get an idea of the cost.
Sent from my SM-G960U using Tapatalk1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
11-26-2019, 10:56 AM #4
- Nov 2019
- Speed
Thanks for the input. Does make sense that the GM crate motors wouldn't use the highest quality parts. anyone know how they hold out??? you guys have hp/ torque numbers on your build??? I am starting to lean toward building my own just out of the satisfaction of doing it my self. Guess thats the whole point of building a car vs purchasing one thats complete. Did some more searching today and found a 190K mile "smoker" from LQK salvage for $600.......
11-26-2019, 10:59 AM #5
- Nov 2019
- Speed
By the way the motor is an lQ9 out of a 02 Escalade...... that year would be pressed in wrist pins wouldnt it???
11-27-2019, 09:19 AM #6
Bottom stock end holds up to about 700hp in boosted applications.
Oh and my LQ4 was from an 02 yr. I did not have to press in the wrist pins.
Building my first AR!!
By Tobynine9 in forum Gun's & AmmoReplies: 14Last Post: 05-28-2010, 05:45 AM -
110k miles worth building
By ls1wallen in forum General HelpReplies: 6Last Post: 09-23-2009, 10:08 AM -
Building an LQ4 6.0 some ?'s
By kealap in forum Internal EngineReplies: 15Last Post: 04-11-2007, 04:30 PM -
Building my LS1?
By jrh68 in forum Internal EngineReplies: 5Last Post: 08-16-2006, 01:59 PM
