Results 1 to 2 of 2
Thread: How to replace Tranny mount?
04-16-2006, 05:41 PM #1
- Apr 2006
- Roxboro, NC
White- 1996 Trans Am
Just busted my transmission mount for the 2nd time and I was going to replace it with a polyurthane one and was curious to see how hard it would be to do myself. Has anyone ever done this before and how do I do it?
Thanks!
04-17-2006, 04:30 AM #2
really easy to do. need to lift the car and support it. then support the transmission. remove the 17mm nut holding the mount to the crossmember. then remove the 4 15mm bolts that hold the crossmember to the car. then remove the 2 15mm bolts that hold the mount to the transmission. then reinstall in reverse order. that's it.
Tranny Mount???
By redbird555 in forum Automatic TransmissionReplies: 5Last Post: 08-29-2009, 10:49 AM -
New Tranny Mount.
By Anthracis in forum Automatic TransmissionReplies: 23Last Post: 06-01-2007, 07:59 PM -
tranny mount
By fastbuff in forum Automatic TransmissionReplies: 3Last Post: 11-27-2006, 04:15 PM -
Need a good T56 (LS1) Stock Tranny mount & Torque arm mount..
By 1slosnake in forum Parts Wanted / TradeReplies: 2Last Post: 06-19-2006, 03:04 PM -
By 1slosnake in forum Parts Wanted / TradeReplies: 1Last Post: 06-13-2006, 05:24 PM
