Results 1 to 16 of 16
    Greene, Iowa
    3 (100%)
    99 Chevrolet Camaro Z-28
    TCI Super street fighter stall converter
    I have a gently used (around 1500 miles) tci super street fighter series lock up stall convertor..it is a 3500 stall. its in really nice shape, but im selling because i wont to go in a different direction with the car this is for the 4l60e. .. asking $350 or best offer on this, might consider patial trade...heres info from tci
    This line of performance converters was developed to work with many GM and Ford late model lock-up transmissions. These transmissions can offer many advantages to performance enthusiasts, including lower initial gear ratios and overdrive gear for lower highway rpm and improved mpg. The Super StreetFighter™ lock-up series allows the car owner to have to 4000 rpm stall speeds (depending on application) while still enjoying all the benefits of a mechanical lock-up converter.
    Features
    •Furnace-Brazed Fins
    •Needle Bearings
    •Hardened, Pre-Ground Pump Hub
    •Computer Balanced
    •Installation Hardware Included
    Benefits:
    •Higher RPM Launches
    •Lower Elapsed Times
    •Better Low And Mid-Range Power
    TCI® strives to produce the best torque converters in the industry. Part of the process involves ensuring that each unit is built to spec. Regardless of what category or price level it may fall into, every TCI® torque converter is Triple Tested during assembly. Once all the prep work on the component parts has been completed, the impeller is welded to the front cover. Immediately following this process, a pair of dial indicators are employed on a rotating table to verify that the impeller body and pump drive hub remain true. Each unit is then pressurized and subjected to a leak test to confirm the integrity of all the weld seams. Lastly, each unit is computer balanced to reduce annoying and potentially damaging drivetrain vibrations that would occur from an unbalanced torque converter. That's Triple Tested so you can be confident you're getting a torque converter that's ready to roll.
    and pics of my actual converter:
    Member jrzdude's Avatar
    Feb 2011
    Phoenix, AZ
    2002 Black WS6
    Interested...So its in perfect operating condition?
    Greene, Iowa
    3 (100%)
    perfect condition...fill it with trans fluid bolt in and go
    Member IH8EVRY1's Avatar
    Apr 2010
    Savannah, GA
    2 (100%)
    PM sent
    Greene, Iowa
    3 (100%)
    pm replied
    Jun 2010
    CT
    88 camaro
    Unhappy
    @SteveCZ28 the Part number that's visible on the torque converter your selling is 242931 which is for a 3000 stall, not a 3500 which has a part number 242932.
    Greene, Iowa
    3 (100%)
    when installed iny my car, it would literally jump right to 3500...
    Jun 2010
    CT
    88 camaro
    oka just had to ask. Pm sent.
    Greene, Iowa
    3 (100%)
    i didnt recieve a pm from you
    Greene, Iowa
    3 (100%)
    for those of you interested. the box is 12W X 12L X 10 H and weighs 36 pounds packaged and ready to go coming from 50636
    Greene, Iowa
    3 (100%)
    ttt
    Nov 2009
    NOVA
    1 (100%)
    2002 C5 - M6 - Blue
    2000 Z28 - A4 - Pewter
    PM'ed ya
    Greene, Iowa
    3 (100%)
    pm replied
    Greene, Iowa
    3 (100%)
    payment pending
    Apr 2011
    PA
    2001 Formula
    is this still for sale?
    Greene, Iowa
    3 (100%)
    sold! thanks guys
  1. tci super street fighter worth it?
    By freaky57fast in forum Automatic Transmission
    Last Post: 05-19-2013, 11:14 PM
  2. For Sale: LS1 TCI 4L60E Super Street Fighter 3600 Torque Convert
    By cpop98ws6 in forum Parts For Sale / Trade
    Last Post: 10-19-2011, 01:38 PM
  3. Street fighter vs tekken wow!
    Last Post: 08-16-2010, 09:40 PM
  4. Super Street Fighter II Turbo HD Remix
    By zero_proto in forum Almost Anything Goes
    Last Post: 12-01-2008, 08:01 AM
  5. TCI Superstreet Fighter 3500 Stall
    By gimmeadonut in forum Parts For Sale / Trade
    Last Post: 05-18-2006, 04:48 PM
