Results 3,461 to 3,480 of 7102
07-31-2014, 12:45 PM #3461
- May 2013
- Nashville, TN
Black / White- '00 T/A M6/'19 Hemi Truck
gettin her ready for this weekend! Dragons tail baby!!!
My Y pipe is leaking at the I pipe connection..trying to decide if I just want to unbolt the I pipe and run it with an open Y pipe or fix the leak...decisions decisions...
07-31-2014, 12:48 PM #3462
Pat, next time you are down my way bring your polish kit and teach me how to do it like you do.....damn that's clean...
07-31-2014, 12:49 PM #3463
- May 2013
- Nashville, TN
haha dude I dont see it...people tell me how good it looks all the time and I just cant get it how I want it "maybe its because I know where every little imperfection is?". I have spent COUNTLESS hours on the paint...now im spending countless hours under the car.
Cleaned the engine bay yesterday for the first time with simple green and im REALLY impressed with how well it looks now. I've always done it by hand until yesterday.2000 Black TA M6 - LT's, ORY, UMI Short Stick, TT2's, Drilled/Slotted Rotors, Braided Lines, and Tuned by Vengeance SCCA and Car Show Approved
06 Quad Cab HHHHemi - Sold
97 Camaro - Sold
08-01-2014, 05:21 AM #3464
- May 2013
- Nashville, TN
fixed my Y pipe leak last night...nothing a couple bolts and a clamp couldnt handle! Went ahead and did the free ram air mod under the lid too. I've done that to every one of my previous Fbody's except this one so I went ahead and did that last night.
Pretty sure my EGR tube that goes into the top of my intake is leaking again tho...I need to rip that system out and call it a day. I yanked the secondary air system out a while back, but didnt touch the EGR yet.
08-01-2014, 06:12 PM #3465
Got my heads back....
see my last post in my 6 liter thread for the details.....http://www.ls1.com/forums/f7/my-6-liter-build-174257/
00 FB Vert - Stock
08-03-2014, 06:21 PM #3466
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
Ugh found a screw in the tread of the rear tire. Not even 4 months old and already punctured. Of course it's close to the side wall of the tire so hopefully a tire shop can fix it.
08-03-2014, 07:05 PM #3467
- May 2013
- Nashville, TN
this...
08-04-2014, 10:51 AM #3468
That looks AWESOME!!!
08-04-2014, 10:52 AM #3469
- May 2013
- Nashville, TN
i've got a thread in the lobby with more video's...im editing some more tonight.
Here's the thread I started:
http://www.ls1.com/forums/f2/trip-up...s-tail-180119/
08-04-2014, 11:04 AM #3470
Your car sounds good too btw.
08-04-2014, 11:06 AM #3471
08-05-2014, 04:48 AM #3472
- May 2013
- Nashville, TN
Ordered some new spark plugs this morning. Got gas up in the mountains this weekend that was advertised as 93 octane but I dont think it was...car started popping after that. Hopefully new plugs will fix the issue...
you can hear it and see it in this video some...started smoking a little bit too.
08-05-2014, 05:41 AM #3473
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
Started Sunday evening and finished yesterday morning, installed UMI LCA's, panhard bar, and tunnel brace. Another step in completion of my dream car. They do make some damm nice parts
99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
Wish list.
Coil overs, Heads & Cam
08-06-2014, 08:18 PM #3474
918 Comp spring just failed while on a HOT date!!! WTF!!!
08-07-2014, 02:17 AM #3475
Yikes! Do you think you smacked a piston?
08-07-2014, 07:48 AM #3476
I over revved my ls1 a few years back when down shifting from drive to 2nd. I was speeding on the beltway and somebody jumped in front of me. (100% my fault, shouldn't have been driving at that speed) I slowed it down and avoided the car by slamming on the brakes and down shifting the car. I buried my tach beyond the numbers and bent 4 valves. After removing both heads, I was pleased to find out that the valves bent and didn't hurt the pistons other then a small scratch/ding in them. I replaced the entire valve train and opted for a new cam while I was there. It's been fine for over 8yrs now, but I got lucky. Hopefully you will have the same luck. Good luck.
08-07-2014, 12:13 PM #3477
Finally got around to getting rid of all the secondary AIR set up.
There is some serious amounts of rubber hose there!!
But not anymore.....
Have to say that Jeff's sticky on this is spot on and i only bled a little!!
LT headers, Kooks Y, Frost tune. Magnaflow cats, all arrived over here and they
will be fitted over the next few days.
Can't wait
08-08-2014, 09:36 AM #3478
ordered my new 427 from ERL today!! The M2 GM LS Dry Sleeve Short Blocks
08-09-2014, 04:48 AM #3479
Your not kidding about all the hoses from the AIR system! You prob lost about 30lbs worth of unnecessary weight. Although I decided to use most of the hoses from the AIR system for my oil breather tank. Left the hoses on the drivers side wheel well and put the oil tank where the air pump use to be. Looks very neat and clean.
08-09-2014, 08:44 AM #3480
Well...
Today i had the car on the lift at my buds garage and the swearing
and cussing began!!
Spent what seemed like an age getting the factory manifolds off.
The coil packs were easy enough on the pass side and an absolute
nightmare on the drivers side due to the difficulty in getting to the rear
most 10mm bolt!! Got all the header bolts out safely though... this was a worry for
me!
Then the "fun" began. The TSP LT headers kinda fit where they touch
We spent about four hours and finally got the drivers side in to where it almost fits but
the engine mount will have to come right off for some serious surgery to allow the header
tube to pass by it (almost has to go THROUGH it!!!!!!!). Also had to "adjust" some sheetmetal
near the drivers motor mount with a selection of hammers and blocks of wood!!!!!!!
As well as that, the pressed steel member just down from the motor mount will have to
have the welded flange SERIOUSLY ground back so the flange of it will pretty much be gone!
We will have to seam weld it back after the grinding. Then , and only then, will the mating face
the header be anywhere close to being in a position to be bolted down to the head!!
I see the pass. side fitment needing the same welded flange being ground
right back to allow the header to go up into a position close to being correct!! I wish i knew
the right term for the bit i am describing, but if you have been there i imagine you know the piece!?
The "fun" will re-commence tomorrow morning. Cannot wait!
Trev
There are currently 13 users browsing this thread. (0 members and 13 guests)
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
