Results 1 to 20 of 35
    Senior Member
    texas
    2000 formula
    ALT upgrade.....in pics
    The C130 that comes stock is kinda weak....so a worth while upgrade is a AD244.....the 244 can come in a 145 amp or a 105 .....so i go the 145 of course.....local junkyard had 1.....40$......now you have to be careful....use a 2003 truck as a part locator guide.....244's come in different brackets and diff excitor plugs......2 pin and 4 pin......f bods are 4 pin...the 244 is a BIT bigger than the 130....it just cleared the PS lines with a little tweakin......the excitor plug with the 244 in was a bit tight stock....to tight for me.....so i spliced in a new plug with about a extra inch of slack.....i did have some new cable to wire from the alt to the batt....needed for the extra amps IMO......but i cut it to short and will have to get more to finish that part of the job.....enjoy
    Senior Member
    texas
    2000 formula
    the rectifier of the 244 is TWICE the size of the 130
    Senior Member
    texas
    2000 formula
    Senior Member
    texas
    2000 formula
    Senior Member
    texas
    2000 formula
    Senior Member
    texas
    2000 formula
    Senior Member
    texas
    2000 formula
    old ALT......see how small the rectifier is
    Senior Member
    texas
    2000 formula
    new plug......woo hoooo
    Senior Member
    texas
    2000 formula
    Senior Member
    texas
    2000 formula
    welding cable i got from tractor supply
    Senior Member
    texas
    2000 formula
    Senior Member
    texas
    2000 formula
    and with the 244 you lose the bracket in the back too
    Senior Member
    texas
    2000 formula
    Senior Member
    texas
    2000 formula
    Senior Member
    texas
    2000 formula
    Senior Member
    texas
    2000 formula
    Senior Member
    texas
    2000 formula
    Senior Member
    texas
    2000 formula
    the high pressure line i loosened and moved....then tweaked it a little.....so it just cleared......the return line was close....but it was fine....no need to mess with
    Senior Member
    texas
    2000 formula
    Senior Member
    texas
    2000 formula
  1. ALT upgrade in pics....pt 2
    By sjsingle1 in forum External Engine
    Last Post: 08-13-2010, 07:28 PM
  2. Upgrade Engine, Upgrade Transmission
    By clovenhooves in forum Firebird / WS6
    Last Post: 12-22-2009, 09:07 PM
  3. Replies: 1
    Last Post: 02-06-2007, 08:48 AM
  4. Simple Upgrade Solutions - Oem Upgrade 2003 Bmw X5
    By Ed Blown Vert in forum Stereo and Electronics
    Last Post: 11-16-2006, 08:18 AM
  5. Replies: 61
    Last Post: 08-05-2006, 04:35 PM
