Results 1 to 3 of 3
Thread: LS1 Specs
10-20-2009, 05:41 AM #1
LS1 Specs
Sticky maybe
Gen III LS1
Block Length: 519.0 mm
Block Width: 460.0 mm
Block Deck height: 9.240 inches
Firing Order: 1-8-7-2-6-5-4-3
Cylinder bank offset: 0.9488 inches
Block design/main cap mounting: Deep skirt engine block with 4 vertical and 2 side fasteners in the main caps
Rotation sensors: Engine block mounted crank and cam location sensors
Weight: 430 lbs for complete LS1 (Add 88 lbs for iron truck block)
Weight of Bare block: 103 lbs
Connecting Rod: 6.098 inches long. On-center beam rod
Piston-pin diameter: 0.940 inch
Crank thrust bearing location: No. 3 (center) main bearing
Oil Pump: Gerotor, driven off front of crankLast edited by blackSS01; 10-20-2009 at 05:46 AM.
┌∩┐(◕_◕)┌∩┐
wouldn't want to fight them!
10-20-2009, 08:49 AM #2
Sticky or is this info posted somewhere else that I don't know about
10-20-2009, 04:36 PM #3
let me check....if not I'll stick it.
cam specs
By RedHot99T/A in forum Firebird / WS6Replies: 3Last Post: 09-18-2010, 12:16 PM -
CAM specs
By Gohard in forum General HelpReplies: 1Last Post: 05-22-2010, 09:29 PM -
GM Specs my ass
By Sarge in forum Almost Anything GoesReplies: 8Last Post: 09-19-2007, 05:40 PM -
LS7 cam specs
By Wheeler99WS6 in forum Internal EngineReplies: 5Last Post: 09-12-2007, 10:58 AM -
Does anyone know the specs..
By Z28_SS in forum Camaro / SSReplies: 44Last Post: 08-11-2007, 07:12 AM
