Results 1 to 17 of 17
    Member 28Marcos's Avatar
    SATX
    99 Z/28
    looking to buy air compressor
    Im looking to buy an air compressor that would be powerful enough to use power tools. What should I look for? HP size? PSI? Gallon size? Enlighten this newbie please!
    Mar 2009
    Kansas CIty MO
    All your questions kind of depend on the tools you are wanting to use, but I'll give you some basics. The main things you want to focus on are CFM (cubic feet (of air) per minute) and tank size. Some portable compressors have impressive CFM numbers by placing a large motor on a small tank, but the compressor runs non-stop and therefore works very hard. I have 2 compressors- one is a 17 gallon, 2 horsepower that puts out 3.3 CFM @ 90 psi. Most air tools are operated at 90 psi, and will have and average CFM requirement listed. Both my impacts are 4 CFM, and my die grinders are a little over 2. So with any extended use, this compressor starts running and keeps running. I also have a 30 gallon 5.5 HP compressor that puts out 6.7 CFM at 90 PSI...this one will run my air tools non stop no problems. This is about as big a compressor as you can get and run off 110 electricity (standard plug in). Bigger compressors run off 220. Bottom line, if you are just looking to air up tires, run an impact wrench, air rachet, die grinder etc I would go for something at least as big as 3.5 CFM and 20 gallon. If you will be using such tools for extended lengths of time, shoot for something closer to 5 CFM. I would recommend staying away from the oil-free compressors as they are louder and I have heard they don't run as long...one of mine is oil free and very loud. Hope this helps a little.
    Member jcws6's Avatar
    Western Pennsylvania
    2002 Trans Am WS6
    I've got a 2HP, 8gal electric compressor (4CFM @ 90PSI). It powers my 650ft/lb impact wrench just fine, and it's easy to move around if you need.
    Member Blue28's Avatar
    Ca.
    Navy Blue
    1999 Camaro Z28
    What voltage?
    2002 Trans Am WS6
    Quote Originally Posted by Blue28 View Post
    What voltage?
    Mine's 110v. Just plugs into a regular wall outlet.
    Ca.
    Navy Blue
    1999 Camaro Z28
    Quote Originally Posted by 28Marcos View Post
    What voltage are you looking for?
    SATX
    99 Z/28
    im looking for something that runs off the standard wall outlet that would power the basic tools like the impact wrench and air rachet. trying to gather some tools now to restore a 48 gmc panel next year with my dad. with that said should i just get a basic model 20 gallon 3.5cfm compressor?
    Ca.
    Navy Blue
    1999 Camaro Z28
    Thumbs up
    Here's a couple I've been looking at.
    FYI, both of these are around $700.
    Quincy 20-Gallon (Belt Drive) Cast-Iron Air Compressor
    Model: 131A20PC3
    http://www.aircompressorsdirect.com/...0PC3/p533.html
    Ingersoll Rand Electric Portable Air Compressor — 2 HP, 110 Volt, Model# SS3F2GM
    http://www.northerntool.com/webapp/w...9041_200339041
    Ca.
    Navy Blue
    1999 Camaro Z28
    2002 Trans Am WS6
    Here's the one I was talking about: http://www.harborfreight.com/cpi/cta...emnumber=40400
    I know Harbor Freight gets a bad rap everywhere. I bought mine around 4 years ago, with a 3 year warranty (just in case). Never used the warranty, and the thing still runs like a champ. Cost me about $100 with the 20% off coupons they're running all the time. I was looking for something I'd be able to haul around if I needed to, while still powering everything I needed.
    Ever since I got my battery-powered impact wrench, I barely ever haul the compressor out anymore. A damn shame.
    Member tpilews's Avatar
    Tampa, FL
    '98 Z28
    I would look around on craigslist if I were you. I picked up a 40 gallon, 5 HP Craftsman compressor for $200. It runs 10CFM @90 PSI and 12CFM @ 40PSI. If you're ever going to spray something, you want a decent 40 PSI rating. Obviously, the higher the better. I've sprayed quite a few things since having it. Bookshelves, benches, coffee tables, etc... It runs all my other tools without a hiccup.
    Oh, mine 240 volts though, so you have to have some electrical knowledge, and it isn't portable. But, that's why I have 250 ft. of rubber line.
    Sep 2009
    US
    I've just bought a 1HP compressor for 100$. Used but in good condition. It's worth searching through used craftsman tools. I've found the one I bought here:
    http://www.pennysaverusa.com/categor...w-us/radius-1/
    Member TA98's Avatar
    Mar 2009
    Maryland
    How many gallons is it?
    Cary, NC
    2000 Pontiac Trans am M6
    take into consideration of the consumption of the air tools you are gonna be using like an impact wrench
    San DEEEE Eggo
    teal
    99 Z28 with an SS complex
    what would be ideal if i want to use one to media blast a car?
    San Diego ca
    "Arrest Me Red"
    2001 trans am
    here is what i use for all my stuff. and if you look at sale add's some times you find it cheper and with some free tools to.
    http://www.sears.com/shc/s/p_10153_1...sName=View+All
    Jan 2011
    NC
    2003 Silverado
    I have this one from Craftsman that I bought 5+ years ago. It runs my 1/2" impact and air rachets with no problems. It is 110v. If you plan to paint or do any blasting, save up for a unit with 12+ CFM at 90psi with a 60-80 gal tank. It costs more, but it is worth it.
    http://www.craftsman.com/shc/s/p_101...=1296241651677
  1. new air compressor
    By Zboner in forum Tools
    Last Post: 07-29-2009, 07:33 AM
  2. WTB: AC compressor for LS1
    By deelli in forum Parts Wanted / Trade
    Last Post: 02-10-2009, 07:58 PM
  3. Air compressor
    By tpilews in forum Tools
    Last Post: 09-19-2007, 05:53 PM
  4. Need an AC Compressor
    By TwistedSS in forum Parts Wanted / Trade
    Last Post: 03-20-2007, 12:09 PM
  5. New A/C compressor
    By fastbuff in forum Corvette
    Last Post: 01-13-2007, 06:09 AM
