Results 1 to 20 of 51
12-03-2008, 02:02 PM #1
Can Synthetic Motor Oil Really Free Up Horsepower?
(1 of 2)
In the high performance automotive world, efforts are always being made on the part of hot rodders to extract every last bit of performance potential out of their vehicles. This quest for horsepower has lead to many breakthroughs in technology used both in racing and in normal street use. The draw back to this area of interest is that in some cases, companies take advantage of consumers with either unscrupulous marketing campaigns, inferior products or a combination of both.
One area of the performance hobby that generates a great deal of interest, and often times controversy, is in the area of motor oil. Oil companies have recognized the performance facet of the automotive world and have met consumers with products they claim will give them a performance advantage. As a result, over the years, consumers have seen an almost endless barrage of products and marketing directed towards the hot rodding crowd. In some cases, these products have been hyped up to a great extent and are ultimately found to provide little or no advantage in performance over similar and less costly alternatives.
For the general consumer, just seeing a specific product on the shelf can lead him or her to recall the latest television or magazine ad where fantastic performance gains and product superiority is touted. Often times this flashy marketing is accompanied by “independent lab tests” that seem to prove what the ad claims. Unfortunately, these ads can be deceiving at times and the independent tests can be less than scientific. One such test that is designed to get to the heart and pocket book of the hot rodder is comparison of products and their demonstrated horsepower gains on a dynamometer. This is a popular tool that is sometimes used by oil company marketing.
So what is ultimately the truth? Can one really believe reported dyno results that indicate one motor oil provides a horsepower advantage over another similar motor oil? Questions like these have caused a great amount of debate and cynicism among enthusiasts.
In this thread we will look at possible inconsistencies that can generally occur with dynamometer results, synthetic motor oil friction reduction theory, and look at two motor oil dyno comparison tests that have shown a horsepower increase in switching from conventional motor oil to synthetic motor oil.
Below, Dave Young of Mopar Muscle Magazine describes dynamometer correction factors, variables in dyno testing, and inconsistencies that can occur when comparing dyno results from more than one dyno. Mopar Muscle Magazine and Amsoil, Inc., team up every year for the AMSOIL/Mopar Muscle Engine Challenge. This challenge is conducted at the Competition Cams testing facility in Memphis Tennessee where all the engines are dynoed on Competition Cams Super Flow SF-902 Engine Dynamometer.
Originally Posted by Dave Young, Mopar Muscle Magazine, (4/2008)
Theory: Synthetics and Friction Reduction
Originally Posted by Amsoil, Inc. (08/2007)
The famed Horsepower TV Conventional vs. Royal Purple comparison
A few years back Horsepower TV performed a Conventional vs. Synthetic motor oil comparison utilizing a Chevy ZZ4 small-block engine. The motor oil used in this comparison was a Standard 10W-30 motor oil against Royal Purple 5W-30 High Performance Motor Oil. The results of this TEST reported a gain of 8 horsepower and 6ft.lbs of torque by switching from the Standard 10W-30 to the Royal Purple 5W-30 Synthetic. This test has since been highly publicized and talked about among automotive performance enthusiasts. But how does the testing procedure used in the comparison stack up scientifically?
One inconsistency that is not hard to catch is the fact that two oil viscosities are used in the comparison. Certainly, Horsepower TV host, Joe Elmore, describes that the 5W rating for the Royal Purple oil stands for the Winter Viscosity rating, while 30 is the rating at high engine temperatures which is the same as the standard motor oil tested. Although, this may seem like a reasonable explanation, there may be an increased margin of error in comparing two dissimilar oil viscosities.
A closer look at the American Society for Testing and Materials (ASTM) test D-445 provides data on motor viscosities at predetermined oil temperatures. In this case, we will look at the Kinematic Viscosity @ 40°C, cSt. Note that 40°C equals 104°F, and cSt stands for centistokes which is the measurement of an oils viscosity while in motion. Motor oil manufacturers generally provided this information in their product data sheets which can be found online. This data was found on the Royal Purple oil used in the test but since the exact brand of the conventional motor oil was not stated, we can only draw a general conclusion on what the actual viscosity would be.
5W – At 104 degrees Fahrenheit, the 5W-30 Royal Purple has a viscosity of 65.3
10W- At 104 degrees Fahrenheit, an SAE 10W rated brand name conventional motor oil generally has a viscosity of 70. However, since we don’t know the actual brand of the black bottle “standard motor oil” used in the test, we can only assume that the viscosity would actually be around 70. This could be a conservative estimate as a generic black bottle motor oil may not perform as well as a top name brand conventional motor oil. We can only assume at this point.
So why is the difference in a 5W and 10W an issue when both oils have the same 30 rating?
12-03-2008, 02:03 PM #2(2 of 2)
While both oils tested will have a similar viscosity at engine operating temperatures, they will start out thicker at cooler temperatures and thin at different rates until reaching normal operating temperature. Notice in the test that they performed both dyno pulls when the oil temperature was 160 degrees Fahrenheit. Since the normal operating temperature for motor oil is 212 degrees, this indicates that both oils would have been somewhat thicker than normal when the dyno pulls were made. Since 10W oil starts out thicker than a 5W oil regardless of type and brand, it would still be somewhat thicker than the 5W when the test was initiated at 160 degrees. Since motor oils are known to thin and thicken on none-linear curves, it is unknown exactly what that actual differences in viscosities would be at the test initiation temperature of 160. This is important because thinner viscosities generally cause less drag on internal engine parts and free up some horsepower. This would seem to indicate that when performing a comparison like this, the elimination of as many variables as possible could help to reach a more meaningful determination. In this case, comparing two like motor oil viscosities may have resulted in a different outcome.
Amsoil Commissioned Conventional vs. Synthetic Dyno Comparison
In early 2008, Amsoil, Inc., commissioned a motor oil comparison. The results of the comparison originally appeared in the June 2008 Amsoil Action News, a monthly publication that Amsoil provides to Amsoil Independent Dealers and Amsoil Preferred Customers. The result of the test can also be found in this LINK.
In this test, two early model Harley-Davidson motorcycles of a like model are tested on a motorcycle dyno as conducted by Cycle Solutions, Inc., a well known motorcycle tuner in the United Sates. The dyno testing on the two bikes is divided up into three segments.
Segment 1 - Is a baseline test that showed the horsepower and torque curves of the bikes with conventional motor oil.
Segment 2 - This test shows the horsepower and torque curves with Amsoil SAE 20W-50 Synthetic Motorcycle Oil.
Segment 3 – Showed the horsepower and torque curves with both Amsoil SAE 20W-50 Synthetic Motorcycle Oil and NGK Iridium Spark Plugs.
When deciphering the results of this test, the questions came up of what exactly was the viscosity of the conventional motor oil used in Segment 1 of the test? Were we up against the same variable of comparing two unlike motor oil viscosities as seen in the Horsepower TV test? I put inquiries in to Ed Newman, Director of Advertising at Amsoil, Inc., Christopher Waddell, Owner/Operator of Cycle Solutions, Inc., and David Anderson, Senior Analyst, Technical Sale Group at Amsoil, Inc. The question was posed as to what was the viscosity and brand of the conventional motor oil used in Segment 1 of the test. Below are their responses.
Originally Posted by Ed Newman, Director of Advertising at Amsoil, Inc. (11/21/2008)
Originally Posted by Christopher Waddell, Owner/Operator of Cycle Solutions, Inc. (11/24/2008)
Originally Posted by David Anderson, Senior Analyst, Technical Sale Group at Amsoil, Inc. (11/26/2008)
Closing Thought
With much profit to be gained within the motor oil industry, oil companies use many different opportunities of attracting perspective consumers, especially those interested in performance. As discussed, one popular way of attracting performance enthusiasts is through dynamometer comparison. The dyno result can often prompt a consumer to purchase a product based off of the reported gains in power as tested. However, a closer look at how some of these tests are conducted may lead to further inquiry and examination of the results. With a little research, one can begin to notice many testing variables involved with this type of comparison. Examples of such variables can include differences in dyno equipment, dyno correction factors, atmospheric conditions, and how the test is conducted. So where does this ultimately leave the consumer when it comes time to spending the hard earned dollar? There really is no simple answer. However, when it comes to the area of the automotive performance hobby, research is the ultimate advantage.
CompSynLast edited by CompSyn; 12-03-2008 at 02:14 PM. Reason: Added link
12-03-2008, 07:39 PM #3
next oil change, i am not doin synthetic. i'll do 4 qts of decent conventional, and a quart of lucas, and supposedly, thats better then any synthetic out there.
that is good info though. but $50+ for an oil change is a little rediculous to run royal purple
12-04-2008, 03:44 AM #4
- Retired Outlaw Sum Bitch
When you overload on a certain additive(s) like Lucas it neutralizes the other additives in your oil and that is a bad thing. Any SM rated oil has the proper amount of additives mixed so you need add nothing.
12-04-2008, 05:55 AM #5
12-04-2008, 06:00 AM #6
- Apr 2001
- Surf City, NC
Black/Screaming Yellow- 99 S/C TA WS6 & 04 Cobra
1999 Trans Am WS6 Black - Forged 346, P1SC (8psi), TH-400, and 12 bolt(3.73's)
10.29@129 w/1.60 sixty foot
2004 Screaming Yellow Mustang Cobra - Whipple 2.3, Exhaust, & CCW's...My DD
12-04-2008, 06:15 AM #7
12-04-2008, 06:15 AM #8
Just a thought, but spending a shitpile of money on an engine to get it in the 9's (hell, even the 12's) then chincing out on the oil is just incredibly stupid.
12-04-2008, 06:17 AM #9
12-04-2008, 06:22 AM #10
12-04-2008, 06:29 AM #11
- Crystal Lake IL
Pewter- 2001 Camaro Z28 M6
I build engines to make horsepower, I dont buy oil to make horsepower, I buy oil to protect those engines.
oil companies that advertise better fuel economy and more horsepower, have found a weakness in consumers and turned into a marketing stunt. None of us bought our LSx cars for the fuel economy (granted they do well on fuel). We bought are cars for horsepower and looks. Now if you are so worried that a certain brand of oil can give you a couple extra horses, then I have a Tornado and some spark plugs to sell you.
Marking gimick RP and conventional oil on horsepower TV. RP is garabage but their marketing is priceless
If your racing is so tight against the competition then start changing your oil between every race.
Fresh oil vs. old oil will produce a bigger difference in horsepower then one oil type vs another, plus the fresh oil is safer on the main bearings over the thicker older oil.
Sarge has listed numerous times what oil to use and what not to use. Take his advice and keep your engine protected, or dont take is advice and spin and bearing.
12-04-2008, 07:41 AM #12
In cold weather synthetic oild does a better job of lubricating an engine on cold starts. Just place two plastic cups on your porch in 0 degree weather overnight and put some conventional oil in one and synthetic in the other. In the morning try to pour them out. If that doesn't convince you of one of the benefits of synthetic in cold climates for everyday use then nothing will convince you.
As far as horsepower, fuel economy, and racing, synthetic does lubricate better, especially at extremely high temperatures, with less breakdown.
The performance and efficiency difference is not enough to justify the often significant price difference for everyday driving but if someo0ne is trying to squeak the last .01 second improvement out of a car at the track, then synthetic is what they are going to use.
I run 20-50 synthetic in my Camaro with the 383 stroker because I don'[t want to mess with oil changes as frequently and I don't want a problem if I go eight rounds of racing and start hot lapping because of a track noise ordinance late on a Sunday night.
I run synthetic 5-30 in my daily driver because it gets a lot of cold starts in the winter. My wife uses cheapie conventional oil in her daily driver because the dealership where she works changes it for her at a discount. I could care less because the bottom line is that clean oil is the single best thing you can maintain in your engine, regardless of synthetic or conventional.
I have two "spare" beaters, a 1990 Lincoln and a 1999 Sebring. because they don't get used much and hardly ever in the winter I just run NAPA conventional 5-30 in them and change it every spring or 3,000 miles, whichever comes first.2002 Street ET Champion New England Dragway
1999 Street ET Champion Oxford Dragway
My Blog is here: http://www.downtime.com
12-04-2008, 08:41 AM #13
12-04-2008, 02:12 PM #14
12-04-2008, 07:21 PM #15
Just curious, where did you see that Lucas + Conventional is better than any synthetic?
A while back the Lucas oil stabilizer was talked about at this LS1.com thread, Lucas oil stabilizer
You’re probably right, the performance gain from switching to a top tier synthetic in a race application may not net any more than a hundredth of a second give or take.
For a street application, you may see some rate of return with better fuel economy to offset the higher cost of the synthetic. For example, the SAE J1321 Joint TMC/SAE Fuel Consumption Test Procedure - Type II has demonstrated an improvement in fuel economy from using a top tier synthetic. But the real rate of return comes from the extended drain intervals that are made possible by top tier base stocks and additives found in some synthetics.
Read more on motor oil performance variables at this LS1.com thread, Base Oils & Lubricant Performance.
I’m liking the vigorous debate!
CompSyn
12-04-2008, 07:33 PM #16
Jesus Christ cliff notes????
12-04-2008, 07:58 PM #17
12-06-2008, 11:29 AM #18
- Jun 2008
- Orlando FL
Red+White Top and Stripes- 2000TransAmConvertible A4
Not to bash anyone, but I think everyone needs to keep in mind that no matter what, every sponsor on this site is going to support and pitch his own product, personally I'll take this with a grain of salt.
As for the part about dyno testing being unreliable, I see the point about the horsepower tv test not being performed at the correct temperature, but they used the same exact engine and same exact dyno on the same exact day, performing the tests one after the other. The variables were as close and fair as would be physically possible, so you really can't discredit it with the "Inconsistent dyno variables" argument stated on the second post of this thread.FAST 90/90, SLP Lid, Kooks JetHot Coated LT's, American Racing Y-Pipe+Magnaflow Cats, DHM Electric Cutout, Flowmaster American Thunder Catback, HP Tuners Software, 343 rwhp.
BMR Convertible Subframe Connectors, Hotchkis Strut Tower Brace, BMR Driveshaft Safety Loop.
12-06-2008, 03:46 PM #19
12-06-2008, 07:10 PM #20
Thanks for your reply. I appreciate your input and objectivity.
Here are a couple other thoughts to consider…
The information provided about dyno testing was not to in any way prove that dyno testing is unreliable. It was only mentioned to show that there are testing variables involved with dynamometer equipment that could or could not play into motor oil comparative testing results; something to consider when looking at these type tests, weather it’s Royal Purple, Amsoil, or whoever?
In all farness, the post said nothing about discrediting any test. Rather, it was alluded to that there were some observable variables involved with the Horsepower TV test as well as the Amsoil test. The reader was left to draw their own conclusion.
Thanks again,
CompSyn
592HP 4.6L 2V Motor For $2,298 - 592 Horsepower For $2,298
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 04-14-2011, 12:10 PM -
6 quarts Pennzoil Platinum motor free after mail in rebate
By kraemer94 in forum Texas MembersReplies: 0Last Post: 11-04-2007, 10:18 AM -
highest horsepower LSX engine? video of 930 hp pull all motor
By powerjon in forum Multimedia SectionReplies: 8Last Post: 07-03-2007, 05:11 PM -
Free window motor fix
By ryan_gilson in forum General HelpReplies: 4Last Post: 04-18-2006, 07:17 AM -
Cosworth Synthetic Motor Oil
By Sarge in forum General HelpReplies: 5Last Post: 03-01-2006, 05:11 PM
