10-25-2008, 03:49 AM #1Member
- Sep 2008
- Atlanta, GA,Ft.Walton Bch,FL
- Blog Entries
- 1
silver- 99 ws6
clear coat and single stage paint ?
car is base coat clear coat (bright silver metalic) can replaced fender be single stage?
is single stage available in metalic?
I have painted a fender in past looked good untill I tryed to add the clear (looked dull) maybe added to much clear.
just trying to avoid the clear step this time, the single stage can be polished to shine as the clear part of car right?
Thanks
10-25-2008, 06:43 AM #2
10-25-2008, 09:06 AM #3
I am not of fan of single stage paint. I would do the base coat clear coat.
10-27-2008, 07:22 AM #4Senior Member
- Oct 2007
- Muncie, IN
00 TA PWTR, 98 VertTA NBM- 80 TA BLK, 80 Formula NBM
i think you can get a better shine with clear and its stronger. . . if the clear looked dull when you applied it, you either didnt get enough on or you simply needed to wet sand and buff. imo, unless youve sprayed clear for years, its almost impossible to spray and get a perfect (or close to) finish. you almost always have to wet sand and buff.
10-27-2008, 07:32 AM #5
10-27-2008, 07:45 AM #6
Paint problems, how to fix clear coat?
By Naaman in forum Appearance SectionReplies: 3Last Post: 12-26-2014, 04:48 AM -
clear coat seperating
By YellaVette3 in forum Showcar and DetailingReplies: 2Last Post: 06-21-2014, 05:21 PM -
clear coat help..
By 98maro in forum General HelpReplies: 5Last Post: 08-09-2012, 12:50 PM -
fly landed in the clear coat
By qwik219d9 in forum Showcar and DetailingReplies: 15Last Post: 04-16-2009, 07:44 AM -
Clear Coat
By flipsutter in forum Appearance SectionReplies: 10Last Post: 03-07-2009, 05:19 PM
