Thread: Antenna install questions
10-23-2008, 11:33 AM #1
I'm new to the forums(I'll post in the new member section when I get home). I have a few questions on installing a new antenna. Here's the scenario...
Some idiot broke off my antenna while I was at work because it would no longer go down. I want to put in a rubber shorty antenna. Another reason I want to do this is because my mom bought me a portable xm radio for christmas last year, but it won't work in cars with automatic antennas.
My questions are:
Can anyone recommend a good rubber antenna?
Is there much to converting an automatic antenna to a stationary one?
Will I need any extra wires or anything else?
Many thanks in advance.
-James
10-23-2008, 11:39 AM #2Senior Member
- Oct 2007
- Muncie, IN
00 TA PWTR, 98 VertTA NBM- 80 TA BLK, 80 Formula NBM
havent done it to a 4 gen but the swap should be fairy simple. id just go with a kit from autozone or something. you shouldn't have to buy anything else.
10-23-2008, 01:13 PM #3
Is there anything I should know about unhooking the motor and running the antenna wire to the actual antenna?
10-24-2008, 01:58 AM #4Impounded
- Oct 2007
- Beaver Dam KY
Antenna wire is a simple unplug.. so is the motor... and the whole unit comes out with a couple of 10mm bolts..
10-24-2008, 05:25 AM #5
10-24-2008, 08:51 AM #6
Now if you buy a stubby that already has the wire on it, you may have to get an extension for it. I did.
Plus you have to make sure the connection on it will fit your radio. If it's a factory radio it will be smaller. If you have an aftermarket one it would be the same.
If it's just the antenna with no wires, I don't know, cause I haven't done it yet.
This is the best pic I have of my antenna.
Power antenna install.....in pics
By sjsingle1 in forum Stereo and ElectronicsReplies: 26Last Post: 11-17-2016, 04:53 PM -
Cam install questions
By MIKEY'S 2002 TA in forum Internal EngineReplies: 16Last Post: 01-25-2010, 05:55 AM -
Help: power antenna install
By Mr.D in forum Stereo and ElectronicsReplies: 2Last Post: 04-14-2009, 07:37 PM -
CB or Amateur antenna install 2002 firebird
By Hooplah in forum Stereo and ElectronicsReplies: 21Last Post: 02-28-2009, 01:52 PM -
Convert power antenna to fixed antenna
By Red 99 T/A in forum Firebird / WS6Replies: 21Last Post: 01-24-2009, 10:40 AM
and i believe a ground screw to the body
