View Poll Results: which would you preffer
Voters
12. You may not vote on this poll
  • Spherical Rod Ends
    3 25.00%
  • Polyurethane Bushings
    3 25.00%
  • Spherical Rod Ends & Polyurethane Bushings
    6 50.00%
Results 1 to 20 of 20
    Member twoolley08's Avatar
    michigan
    2000 trans am
    which end links are better
    for the panhard barand lower control arms toque arm and whatever else there is. which end links would be better and why? the dual Spherical Rod Ends or dual Polyurethane Bushings or poly and spherical combo?
    Cedar Rpaids,IA
    1998 Camaro SS
    Spherical Rod Ends are the best because they allow full articulation of the suspension with out any binding or deflection. The down side to them are they are noisy and well give a rougher ride because there is no bushings to give any damping of bumps etc.. To quote Herb Adams chief engineer for the 4 Gen F-body suspension and well know racing and suspension guy “running spherical rods for all suspension point well give your car racecar handing, but at the cost of roughness and road noise.
    I personally have rod ends on all my suspension points and yes it added a lot of noise and rides some what harsher, but the handling improvement made it worth it for me. But then again if legal I’d drive a Sprint Cup stock car to work. lol
    1998 Camaro SS Hard Coupe Bright Red #1593
    Mods: Lots!!, still my daily driver except for winter
    383rwhp 370rwft/lbs
    1979 Corvette
    Mods Lots!!, weekend cruiser
    325rwhp and 320rwft/lbs
    2007 Dodge Ram 1500 4x4 (Yes its got a HEMI)
    Mods: Catback, BFI CAI, Winter daily driver
    michigan
    2000 trans am
    Quote Originally Posted by vetteemt View Post
    haha same here, i havent bought ne thing yet to get sper rod endsbut most likely i will considering i have a loud exhuast, a loud sound ssytem- including two 15in subs in the back seat, and rough ride?.?.? well its lowered some and has low pro tires how much rougher can it possible get
    Cedar Rpaids,IA
    1998 Camaro SS
    It’s hard to explain, it’s not harsher like its going to bruise your kidneys. It’s more that the forces you feel from bumps are sharper and more intense.
    Brookville, PA
    2001 Z28
    Why not consider combo parts like these:
    Panhard bars:
    http://www.stranoparts.com/partdetai...D=67&ModelID=7
    LCA's:
    http://www.stranoparts.com/partdetai...D=96&ModelID=7
    The rod-end eliminates any bind, the poly bushing mounts to the body side to help temper any potential noise from the rod-ends (though these aren't really rattly rod-ends like the cheapies some companies use).
    And there is even a combination package that offers a small discount for getting both the 2016 and 2021 together that saves another $5 or so.
    Sam Strano
    SCCA National Champion (x6)
    SCCA ProSolo Class Champion (x5)
    2009 SCCA ProSolo Overall Champion
    Owner--Strano Performance Parts
    814-849-3450
    Greensboro, NC
    2002 Trans Am WS6 M6
    Quote Originally Posted by Sam Strano View Post
    I have the same package on my car and while there is a little more noise from the rear, the ride is not much rougher and from the amount of improvement in the way the car launches it was well worth the minor amount of noise and loss of ride quality. But then again these are not cars you buy for comfort.
    That guy thearborbarber's Avatar
    SoDak
    White over Red
    1991 Suburban
    I used edelbrock's new non adjustable lca's with a rod end and poly end.
    michigan
    2000 trans am
    Quote Originally Posted by thearborbarber View Post
    how does that set up handle compared to stock
    SoDak
    White over Red
    1991 Suburban
    Any of the listed are better than stock units, mainly due to the rap rubber bushings. I liked the edelbrock combo because the rod end allows free movement and the poly bushing keeps things tight.
    http://www.jegs.com/i/Edelbrock/350/5274/10002/-1
    Brookville, PA
    2001 Z28
    FWIW, you could pay $256 and change for the Edelbrock's (and I sell Edelbrock as well), but it's a waste of $77 *and* you can't adjust them if need be.
    I can't recommend those over the UMI single adjusts I prefer and are $179 and able to adjusted if you want to or need to.
    This is a case of the name driving the price. What's more, if /when the spherical bearing wears in the Edelbrock they are more costly and harder to replace. You just screw a new rod-end onto the UMI's if that happens.
    michigan
    2000 trans am
    always into upselling lol, do you match prices? and free shipping on $99 and over?
    Brookville, PA
    2001 Z28
    In all honesty, I don't enjoy playing pricing games. Many vendors do that because they can't offer the level of tech, or spend the time I do with customers. If I'm way off on price, I do my best to get competitive, but I know on the UMI parts I am not way off on price (and in general try not to be).
    I'm not adverse to hearing quotes you have, but there are a few things to consider.:
    It's infuriating to be used for knowledge only sometimes have found my time was wasted when folks take the information I share and run off to buy parts from the low-baller without giving me a fair shake on the sale.
    I can't stand, as I'm sure anyone else couldn't stand being nitpicked over a few bucks considering the time and effort I spend trying to help folks out. When it happens, I make notes of who did it (screen names and so on) and don't offer advice to those folks again and am more cautious about what I freely offer up as far as advice.
    In a nut-shell it comes down to this. Service before and after the sale. Some folks offer it, some don't. It takes time to do it, I take the time which takes time from other sales. I can't do the volume some other do (which means I pay more for the parts too since my discount is smaller), and yet *STILL* sell for a more than fair price. All the while often being the only vendor here trying to help.
    IF it's about saving $2, I'm probably not your man.
    michigan
    2000 trans am
    yea i hear you on all that, so far the only thing that has caught my eye from quailty and prices are the umi stuff. but when i do buy the lca and panhard im going to want dual rod ends, i dont want much play in the rear since the tires already are rubbing inside the wheel well. 2$ is not much of a difference over service quailty. id rather have good customer service rep that i can call if i run into problems, and call for advise on how to fine tune the rear
    Brookville, PA
    2001 Z28
    I agree. UMI stuff is great (which is why I carry it and sell so much of it).
    A package is there for all rod-ended stuff too:
    http://www.stranoparts.com/partdetai...D=90&ModelID=7 Available in Red or Black--your choice.
    michigan
    2000 trans am
    6 votes 213 views....hmmm come on guys do some voting here
    Member frisco88's Avatar
    Feb 2007
    Rigaud,Quebec
    Red Orange Metallic
    1998 Trans Am 6spd
    I have double adjustable lca's and panhard and i don't mind the ride but i don't like the noise.I will change them overb the winter for rod and poly ends
    michigan
    2000 trans am
    Quote Originally Posted by frisco88 View Post
    is the noise really that bad? is your exhaust loud? i run mine open pretty much every time i drive the car sooo, you think you would hear it over that?
    Feb 2007
    Rigaud,Quebec
    Red Orange Metallic
    1998 Trans Am 6spd
    Quote Originally Posted by twoolley08 View Post
    i have slp loudmouth 2,but i work a couple of miles from home and the streets are terrible so they're always working,but as soon as you get 2 hiway speeds and crank the stereo,you won't hear them after that.If ur running open exhaust or louder then me then you won't hear it as much.
    michigan
    2000 trans am
    thanks for that info i aprreciate it
    Member Blue28's Avatar
    Ca.
    Navy Blue
    1999 Camaro Z28
    Lightbulb
    For the panhard bar poly/rod-end.
    For the LCA J&M poy-ball/poly-ball, and also rod/rod.
    IMO, LCA with poly/rod-end still limit articulation of the rear suspension.
  1. links?
    By dklowrider in forum Corvette
    Last Post: 04-29-2010, 06:04 PM
  2. End links?
    By patriot1136 in forum Suspension and Handling
    Last Post: 10-22-2009, 06:17 PM
  3. Need Help! Need Links!
    By Whiteboycntdnce in forum Drivetrain
    Last Post: 12-29-2007, 05:54 AM
  4. TV-links
    By SeVeReDiStOrTiOn in forum Almost Anything Goes
    Last Post: 07-13-2007, 09:15 PM
