    Junior Member nosvet's Avatar
    Jasper, GA
    1999 Trans Am
    slight ticking noise, sounds tinny, in dash
    OK,
    Anyone ever notice a slight ticking noise on the passenger side, behing the dash panel? It sounds alomost like a duct flue or damper makes in the wind.
    Makes the noise in relation to turns and starts and stops. I was thinking maybe something like a motion sensor for the alarm?
    Anyone know what this noise is and is it nornmal for a car this age? 1999.
    in my Trans Am
    2000 Trans Am WS6
    i got almost the same thing that i am dealing with now.....i did remove my cd player yesterday and found a harness that wasnt plugged in, I think it is for the cd changer option. I beleive that is what was making the noise for me..
    Member One_Bad_TA's Avatar
    Jan 2008
    Cleveland, Ohio
    2000 Trans Am WS.6
    Mine does this as well. Try turning off the ac/heat and see if the sound goes away. It did for me and when i would put the blower on higher the ticking would speed up
    Jasper, GA
    1999 Trans Am
    tinny ticking noise, in dash in front of passenger
    Nope! That's not it. It does it with the heat or ac on or off. Its definately sounds like something that is balanced and when you made an abrupt turn or acceleration it falls off center and then it kind of ticks as it bounces back and forth until it centers again.
    Its in front of the passenger, somewhere in the dash, possibly mid way toward the firewall.
    It only does it when the var is jostled or shaken.
    Sound like a damper in a furance flue system when the wind blows and the weighred damper kind of racks back and forth for a few seconds.
    Its driving me crazy not to know what it is. I've never heard a noise like this in a car.
    might have a leaf caught in your HVAC fan. it's located under the passenger dash. Just start takin' stuff apart and you'll find it, it looks like a big aluminum bell when you look up from below the dash. Twist that nut and the whole unit should come down.
    Jasper, GA
    1999 Trans Am
    Nope, no leaves and this is deffinately not related to the hvac or the fan. This will occur even if the car is off, and you really shake or jar the car.
    Every morning all the stupid and incompetent people I know get together and think of ways to make my life more difficult!
  1. Ticking noise on highway sounds like a valve
    By 180ls1 in forum General Help
    Last Post: 04-15-2024, 09:11 AM
  2. slight tick noise
    By redrocketws6 in forum Firebird / WS6
    Last Post: 11-11-2010, 08:13 AM
  3. What does this ticking sounds like to you?? VIDEO !!
    By 5abivt in forum External Engine
    Last Post: 10-27-2010, 11:36 AM
  4. Starting to hear a slight ticking ....
    By 5abivt in forum General Help
    Last Post: 07-07-2009, 09:49 PM
  5. slight Ticking noise after intake install
    By ViperSniper in forum General Help
    Last Post: 08-27-2007, 11:47 AM
