    Junior Member GONZO SS's Avatar
    NJ
    pewter
    2000 SS
    Door lock Not working!!
    What's up guys, I have a 2000 camaro that i've been having some problems with. The passenger side door lock just stopped working one day so i figured it was the actuator. I went and replaced it but it didn't fix the problem. Then i purchased a new bcm and still no dice! The weird thing is that if i use the key fob the passenger door unlocks but wont lock, if i use the door buttons it wont do neither. The driver side works perfect. I checked all the lines and they seem ok. I would greatly appreciate any help !!!!
    Aug 2000
    Indy
    is the plastic tab ( the one with the red on it so when you look over you can easily identify if it is locked or not) on the lock all the way in ? maybe it is getting jammed.
    04 C5 A4 Torch Red - sold
    2009 CTS4 Ice Black - sold
    2013 1500 Silverado Z71 - sold
    02 Z/28 M6 Onyx Black All Options - Sold
    2014 Caddy CTS4 - DD
    2016 Silverado 2500HD
    2020 Caddy XT6
    2020 2SS Vert
    NJ
    pewter
    2000 SS
    No its loose and i don't even here the actuator working.
    Feb 2006
    2002 WS6
    A common place for failure is the wiring between the door and door jam where it flexes all the time. For some reason the door lock wiring is always the first to go. Did you check the wiring on the drivers side and test that switch?
    NJ
    pewter
    2000 SS
    yeah the driver side works fine...I have to check the wires inside the door jam gap, thanks for the advice!
  1. Power door lock doesn't work on drivers door..
    By 99RedTa6spd in forum Firebird / WS6
    Last Post: 09-03-2014, 08:20 AM
  2. JHP Door Lock Kit 04-06 GTO
    By CamaroFan71 in forum Parts For Sale / Trade
    Last Post: 08-06-2012, 01:32 PM
  3. Drivers side key lock isn't working
    By 86 IROC-Z in forum General Help
    Last Post: 10-22-2006, 09:54 AM
  4. door lock covers
    By jafg in forum Appearance Section
    Last Post: 09-03-2006, 08:08 AM
