Results 1 to 20 of 31
    Junior Member cdorch's Avatar
    Cape Cod
    1998 Z28 M6
    cam without valvetrain upgrade?
    whats the biggest cam i can go with without having to change the valve springs or anything else?...i want a pretty lopy idle if possible
    The stocker.
    Cape Cod
    1998 Z28 M6
    thats what i was hoping wouldnt be the answer haha...is a valvetrain upgrade going to be a pain on this car? im gona be doing a cam along with headers on my winter break this year
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    The stocker.
    lol.. thats a sad truth tho.
    High performance pontiac did a mag on it. Its not that hard you just have to have a few specialty tools for the LS heads(on car spring compressor, etc )
    Valvespring swap is time comsuming. But not extremely difficult.
    Cape Cod
    1998 Z28 M6
    is that all thats involved? say if i went with something big like a ms3 or 4...just need springs that support the higher lift?
    And pushrods.
    Member Z28_06374's Avatar
    May 2008
    CT
    Any cam you go with will require new springs...if you go with a mild cam like a hotcam you can go with some cheap ls6 springs ($50) and you wont have to change pushrods or anything else. It took me a day and a half by myself to change them out.
    2 SS's are better than 1 Jays00ss's Avatar
    Lathrop, Missouri
    NBM / Silver
    00 SS / 71 SS Elcamino
    you can't just "drop in" a cam without doing anything else and expect to get 75-100 HP. You need to compliment it all with a better intake, Heads, exhaust, and AT LEAST the correct valve springs to handle all the extra lift. If you do not change the valve springs to match the cam, be prepared to suck a valve and have it sticking out the top of your piston.
    You need to have a basic understanding on how a engine works. More cam = more air and fuel as well as exhaust leaving your engine. You need the componets to handle all that extra airflow or you will do nothing but choke the cam and not allow your engine to breathe properly.
    I wish it was that easy to do, but be prepared to spend a couple of G's when you go to put a nice sized cam in.
    With all my mods to my car I am only at 410 rwhp and beleive me it takes a whole lot more than just throwing in a cam without any thing else.
    Member supaxero's Avatar
    Sep 2008
    desert
    metallic pewter
    2000 Trans Am WS6
    defiantly upgrade springs and maybe rods. You going to put extra stress on old components.
    Member zmg00camaross's Avatar
    missouri
    pewter
    2000 camaro ss
    i have gm hotcam with ls6 springs with slp lid 4.10 very streetable works well u can tell it got a cam not extreme but recommend a tune
    Cedar Rpaids,IA
    1998 Camaro SS
    Springs and pushrods are a must. The stock GM pushrods are known to bend and they are not hard to replace. I'd also switch to titanium retainers as well, they are not a must, but well reduce the weight of the valve train and every oz. you reduce out of the valve train the less chance you have to float a valve. Look at them like a cheap insurance policy.
    Personally I have the Patriot Performance's Gold spring kit it includes 16 Patriot Gold dual springs .650 inch max lift, 16 titanium retainers, 32 Super 7 Machined locks, 16 .505" ID machined spring bases, and 16 viton rubber seals and its only $255 from their web site. Take in count the cost of repair or replacement of the heads and/or engine if you float a valve $255 is not that expensive.
    1998 Camaro SS Hard Coupe Bright Red #1593
    Mods: Lots!!, still my daily driver except for winter
    383rwhp 370rwft/lbs
    1979 Corvette
    Mods Lots!!, weekend cruiser
    325rwhp and 320rwft/lbs
    2007 Dodge Ram 1500 4x4 (Yes its got a HEMI)
    Mods: Catback, BFI CAI, Winter daily driver
    JUISSED Midnight02's Avatar
    Feb 2007
    Atlanta
    2002 Camaro SS
    Like the others mentioned -- springs and pushrods are a must and you'll need a tune after the install.
    Many people choose to try to get by without a tune or pushrods because of budgeting issues, however those are the people that typically need the added safety those components provide the most (because they're financially unable to pay for the cost of a rebuild).
    As for the tools and labor required -- it will take hours to properly complete the valvetrain upgrades, however they are well worth the time it takes to install.
    Member NorthwoodDavid's Avatar
    Arlington
    1999 Trans-Am
    once your in there might as well get an oil pump, its a 98.
    when i did mine i spent abt 1k on parts when it was all said and done. And a weekend of course. but you can sometimes find used cam on hear that are pretty cheap bc people want to go bigger, well if your looking for a mild cam.
    Cedar Rpaids,IA
    1998 Camaro SS
    Quote Originally Posted by NorthwoodDavid View Post
    I did not see that. Yes most defiantly replace the oil pump since it’s a 98. 98 LS1 oil pumps have been known to just stop working suddenly with out warning.
    May 2008
    CT
    Quote Originally Posted by vetteemt View Post
    I didnt change anything but the springs when I put my cam in. If the oil pump didnt die yet (114K) its not going to, granted its a baby cam but if its not broke dont fix it....
    Cedar Rpaids,IA
    1998 Camaro SS
    Quote Originally Posted by Z28_06374 View Post
    You probably have one that’s okay. The problem is when they fail you suddenly lose all oil pressure and with no oil pressure it does not take very long for the bearings, rings, and cylinder walls to start taking damage. Not to mention the lifters are very unhappy with out oil pressure either. So it’s normally recommend then doing a cam on a 98 it’s safest to just replace the oil pump while you have it off.
    Member BlueMagicSS's Avatar
    Oakland, California
    Candy Blue
    Yeah.... you'd have to change the valve springs and pushrods... otherwise you can float the valves.... it's better to do it once right than to have to do it over again.... just my .02
    2000 Camaro SS, M6, Edelbrock LT's, Eibach Pro-Kit, Edelbrock Adjustable Coil-Overs
    1986 Camaro Iroc LS1 Swap In Progress
    Blue Magic...
    Like Pepsi It's A Brand Name...
    I agree and the price of the ported ls6 pump is peanuts compared to the cost of the damage a failed pump can cause.
    Beaver Dam KY
    79 T/A -91 Firebird
    this comforts me...
  1. complete valvetrain upgrade. EPS CAM!!!
    By lipsasaurus in forum Parts For Sale / Trade
    Last Post: 08-16-2013, 05:20 AM
  2. Replies: 19
    Last Post: 06-28-2012, 12:47 PM
  3. Valvetrain Upgrade
    By ls1camino in forum Internal Engine
    Last Post: 11-18-2008, 04:08 PM
  4. when is time to upgrade valvetrain?
    By greatwhiteZ28 in forum Internal Engine
    Last Post: 09-06-2007, 05:05 PM
  5. Simple Upgrade Solutions - Oem Upgrade 2003 Bmw X5
    By Ed Blown Vert in forum Stereo and Electronics
    Last Post: 11-16-2006, 08:18 AM
