Results 1 to 2 of 2
10-11-2008, 03:56 PM #1
Corvette Part out C5 2000 & 1998 Look!!
I have a 2000 and a rear clip of a 98 c5 available for parts. The 2000 i have some parts left the 98 is pretty much all there. The 98 does have a gray interior. I will be tearing it apart and all parts will be ready for shiping. The 1998 is an auto car that sustained HEAVY front damage as of right now till i have the body cut away i wont know how the trans housing looks the torque tube is cracked. Items listed below are from the 2000 as of now the 98 stuff will be added as i get it off and inspected for condition. So let me know what you are looking for and i will make it a point to get those done 1st. Thanks
Click Here to View Pics
http://www.picturetrail.com/sfx/albu...46?&offset=200
HUD Complete Kit Instrument Cluster with Switch and Bezel, Projector, and Dash Surround SOLD
Complete Black Carpet Set w/Hard Covers SOLD
Seat belt Retractors only, no receivers SOLD
Radio Bezel- has small un-noticable crack in very top left SOLD
Center Console w/Lid- Has small rip SOLD
Pass. Air Bag (SRS) switch $20 shipped
Glove box- Does not have latch SOLD
Glove Box Light & Switch SOLD
Active Handling Switch/SRS Off Light SOLD
Fog Light/Trunk Pop Switch SOLD
Drivers Mirror no options elec. only SOLD
Drivers Door Panel With Reflector and Handle Bezel Black Excellent Shape SOLD
Drivers Door Exterior Handle w/Rods $40 shipped
Drivers Door Interior Handle/Lock SOLD
Drivers Door Lock/Latch $30 shipped
Body/Door Catches w/Shims and Bolts SOLD
Drivers Door Bose Speaker $30 shipped
Pair Rear Bose Speakers SOLD
Bose Stereo Amp (Gold Thing Coupe) $30 shipped
Drivers Door Window Regulator w/trac. SOLD
Drivers Door Theft Module w/Wiring SOLD
BCM Computer SOLD
Drivers Foot Rest SOLD
Inside Temp Sensor $15 shipped
Knee Bolster Excellent Shape Black SOLD
Hood Pull w/ Cables SOLD
D/S Hood Latch/Bumper 2pcs SOLD
Yaw Sensor GM pt# 10277333 Sits in Radio/Heater Frame $80 shipped
2-Rear Hatch/Glass Latches $30 pr shipped
Targa Top to Body Hardware SOLD
Wiper Motor and Transmission Assembly w/Wiper Arms SOLD
Dash Board Good cond. 1 Tab Broken R/F Come with Vents and Hazard Light Switch $100 Willing to ship approx. $80-100
L/R 1/4 Panel w/Fuel Door SOLD
R/R 1/4 Panel SOLD
Rear Tail Panel SOLD
Rear Hatch w/Excellent Glass and Defrost $400 **PICK UP ONLY**
L/F Air Dam for Brakes $20 shipped
Horns SOLD
A.I.R. Pump With Hoses SOLD
Fuel Door Pop Switch $10 shipped
Rear Tail Light Wiring Harness SOLD
Rear Tail Light Set SOLD
License Plate Holder w/Bezel SOLD
3RD Brake Light SOLD
Complete Inside Wiring Harness only thing that is missing is the pigtails for the power seats. $100
Rear Speaker Surrounds Black $50 Shipped
Rocker Trim Pieces Black SOLD
Overhead Panel Piece between Targa and Rear Hatch Black $50 Shipped
Front Trim Pieces Small Black Transition pieces on A-Pillar $20 Shipped
Underhood Seal Piece Around Battery Box $20 Shipped
(2) Chrome Center Caps $25 Shipped
A-Pillar Triangle Pieces Plastic glued to Windshield Frame SOLD
Misc. Interior HVAC Defroster/Routing Tubes $25 Shipped
HVAC Box Assembly $100 Shipped
1998 Corvette Coupe
R/F Window Regulator SOLD
Power brake booster with prop. valve and master SOLD
OEM computer has been wet would make good core/rebuild $40 shipped
can get numbers if needed.
Gray Rocker Trim Pieces have slight wear $50 Shipped
Gray Carpet Cargo Area with corner pieces and waterfall (needs slight cleaning) $150 Shipped
Black Speaker Trim excellent shape $60 Shipped
Gray Seatbelt Trim slight wear $50 Shipped
Gray Glove Box w/latch $60 shipped
RH outside door handle Silver $40 shipped
Center Console lower part. good shape except for cracked where nuts go to hold it down....it is not noticable when installed $40 shipped
L/R Silver 1/4 Panel with fuel door $140 willing to ship $100-$125
Rear Hatch Silver W/Glass slight chip in fiberglass $300 pick up only
Rear Bumper impact cusion $90 shipped
Rear 1/4 Inner Structure $50 shipped
2 Rear Hatch Seal to Tub $50 Shipped
Washer bottle with pump SOLD
Steering Shaft $50 shipped
R/H Inside Door Pull $25 shipped
Stock Air Bridge $20 shipped
Cooling Fan Motor W/Blade $45 shipped
Dash Vents w/hazard switch $40 shipped
Rear Turn Signals $30 pair shipped
Tail lights 3 good 1 chipped not noticable when in SOLD
Passenger door lock/latch $30 shipped
Fuel Door Pull $25 shipped
HVAC Control Nobs only 2 $15 shipped
Targa Top Latch LH side $30 shipped
Targa Top Center Latch w/trim SOLD
RH Door Module 1 broken tab $60 shipped
Trunk Pop Switch $25 shipped
1 polished Wheel Center cap $15 shipped
Smog/Air Pump SOLD
Air Bag module/sensor bags were poped make offer!
Rear Calipers W/Pads $100 shipped
ABS Unit (HBCM) unit, i believe it fits 97-99 only $200 shipped
Both Fuel Tanks $125 ea. Shipped
Both Fuel Pumps $125 Shipped
R/H Fuel Tank Skid Plate $60 shipped
Rear Diff and auto Trans SOLD
Parking Brake Handle SOLD
Parking Brake Boot $30 shipped
Rear Suspension cradle SOLD
1 Rear Tie Rod $40 shipped
Rear Complete Suspension UCA/LCA/Knuckle/Bearing $250 each side
Rear Leaf Spring $75 Shipped
Rear shafts oem 1 has rip in boot from pulling $60 each shipped
Torque Converter $125 shipped
Torque Tube Carrier Bearing SOLD
10-27-2008, 03:44 AM #2
to the top
HE WHO DIES WITH THE MOST TOYS WINS!!!
2001 Camaro SS T-Top M6 19" Rims Baer Brakes
http://www.picturetrail.com/oneslowz28
OneslowCustoms.com American Racing & Foose Wheels & Magnaflow & Flowmaster Exhaust Skyjacker Lifts
http://oneslowcustoms.com/index.html
Question: 1998 Corvette PCM vs 1999-2000 F Body PCM
By 1slowbusa in forum Computer & TuningReplies: 7Last Post: 04-20-2012, 09:41 AM -
Help: ODD Request! need 1998 trans am part
By speedracer25f in forum Firebird / WS6Replies: 0Last Post: 06-07-2010, 05:06 PM -
Need part number for a headunit for 1998 Trans Am
By ras2247 in forum General HelpReplies: 1Last Post: 12-11-2007, 12:33 AM -
2000 z28.. looking to get this car to part out anybody see anything you need
By icemanfour662005 in forum Parts For Sale / TradeReplies: 4Last Post: 05-18-2006, 02:29 PM -
1998 Calipers Replacement part
By jim_usa in forum General HelpReplies: 6Last Post: 09-20-2005, 11:53 AM
