Results 1 to 14 of 14
    in my Trans Am
    2000 Trans Am WS6
    Amsoil OIl Flush
    I was thinking about getting some Amsoil Engine Flush. I was wondering if I will have to drop the pan afterwards to clean up the stuff that goes to the bottom. Is this a must? anyone with experience on this? Wondering if the loosened particles will end up causing oil pressure problems..
    Retired Outlaw Sum Bitch
    Quote Originally Posted by TransAm11973 View Post
    I use it from time to time and have for a few years now. I use it in mildly/heavily neglected motors. It literally "melts" the gunk and it drains out.
    I follow this regimen and have never had nothing but very positive results.
    1. Change filter and replace with new filter. Add Amsoil flush to sump.
    2. Run the motor 15-20 minutes giving it a 2-3K RPM rev every so often.
    3. Drain and replace oil filter and refill with some el cheapo oil.
    4. Repeat step 2.
    5. Drain and fill with whatever your oil of choice is and go.
    I can tell you I have had excellent luck with it cleaning/flushing the motor. Great product.
    in my Trans Am
    2000 Trans Am WS6
    do you think i need to worry about it clogging the filter on the oil pick up tube? My ls1 has 66000 miles on it, only seen synthetic and has been kept very well..I am just worried that if I put the flush in that its going to make my oil pressure drop and possibly clog the pick up filter or pump....thx
    in my Trans Am
    2000 Trans Am WS6
    also if I decided to go with autoRX instead, is it ok to run it now in the colder months or should I wait until spring. I am in DE, it gets cold but not like the upper states.
    No.
    2 different things here. AutoRX is a long term cleaner (6000 total miles between cleaning and rinse phases) and Amsoil is a solvent flush. Ambient temps have no effect on AutoRX.
    in my Trans Am
    2000 Trans Am WS6
    is autoRX better than the amsoil flush? will it have better cleaning capabilities? So this amsoil flush wont make chunks of crap fall to the bottom of my oil pan? It will liquify everything?
    Member CompSyn's Avatar
    Pacific NW USA
    Post Amsoil Engine Flush
    I have used the Amsoil Engine Flush myself on a car that had 130k on it with good results. If you are serious about doing the flush and want the best result, go by the recommendation and install a new oil filter before doing the flush.
    When I did the flush on my car, there were no “chunks” of material that came out. Only very fine black particles suspended in the old motor oil which poured out of the oil pan drain like water. It’s a good product, nothing to worry about.
    Amsoil Engine Flush is designed to be a preparation cleansing before switching to synthetic motor oil. It is designed to be drained out before the new oil is added. Amsoil does not recommend the use of additives with their oil.
    CompSyn
    No chunks. All you willl do is flush/clean your motor internals. A clean engine is a healthy engine. Amsoil Flush is a one shot cleaner. AutoRX is also but mainly a long term ongoing maintenance type cleaner.
    And no you wont have chunks for the last time
    old timer blue02Z's Avatar
    2002 Z28
    i have used both with good results, i really like auto r/x, amsoil flush is damn good shit too. if i were you i would run auto r/x to gently clean the engine seals and what not, then after a few oil changes run some amsoil engine flush thru is as a "follow up"
    in my Trans Am
    2000 Trans Am WS6
    thanks for the input guys........i know i am paranoid.....but i cant help it my car is my baby. haha thanks again.
    in my Trans Am
    2000 Trans Am WS6
    one other question.....is amsoil foam throttle and intake cleaner safe to use on our composite intake manifolds, etc?
    I dont take this stuff lightly myself.
    Never used it before...couldn't tell you myself....mebbe somebody will chime in.
  1. Transmission Flush
    By pajeff02 in forum Automatic Transmission
    Last Post: 05-12-2011, 08:06 AM
  2. Flush 411
    By Sarge in forum Automatic Transmission
    Last Post: 12-27-2010, 02:25 PM
  3. Amsoil flush
    By freddy_caprice in forum General Help
    Last Post: 09-24-2009, 06:13 AM
  4. Coolant Flush
    By Sarge in forum GTO
    Last Post: 04-13-2008, 08:07 AM
  5. Coolant Flush
    By samson_420 in forum General Help
    Last Post: 10-28-2007, 08:21 AM
