Results 1 to 20 of 20
    Jan 2008
    SoCal
    1997 Nissan with 02 LS1
    high revving ls1?
    1. how high can ls1 rev to with internal mods?
    2. what is needed to achieve this type of rpm?
    3. will the engine still be street capable?
    4. what is the highest rpm you saw/heard on ls1?
    5. do you have any video link?
    thanks in advance.......
    why do you want a really high reving LS1???
    Jan 2008
    SoCal
    just wondering. i was going through a magazine and the new M3 can rev pretty high for a v8( i think in the 8K range....) so i thought why not ls1?...... thats all.
    it would be pretty crazy to hear ls1 rev to 8500rpm or so....haha.
    it would all depend on the internals... certain cams like a MS4 are high reving cams... the valve train would have to match that cam...
    Jan 2008
    SoCal
    i see.... does it require changing out the crank too? some say ls1 crank is good for 8K rpm......
    I wouldn't want to take the stock shortblock above 6800 regularly.
    If I was looking for a high revving LS1...I would probably de-stroke it a bit (down a few cubes) but safely spin to 8500 or so. Just need a cam and valvetrain to spin it that high.
    I spin my 402 LSx to 6700.
    Powerstrokin LT1 > LS1's Avatar
    Aurora IL
    Trans Am owner
    former
    you need heads with a lot of velocity. the bmw can get away with the high rpm's due to the tiny stroke.
    think about it.....the smaller a motor gets, the better it revs (usually)
    chevy 350.....not so great
    chevy 327 .....pretty good
    honda 4 cylinder real good
    sport bike engine.......WOW
    nitro rc car motor...... 40,000 rpm.....yes forty thousand.
    overall you need rods that wont stretch, good studs and bolts, and you need light valavetrain, and a great flowing head.
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    This thread reminds me of something.
    Any of you old enought to remember the Original Z28 engine `67-69 ?
    The Old 302 which was a 327 block (4.00" bore) 283 crank (3.00" stroke).
    It had the 2.02" 1.60" valved 327 Fuelie heads, 11.75;1 compression, a Solid lifter 254/254 @ .050 with 485 lift Bumpstick, Aluminum dual plane Highrise with a big 780 cfm Holley. Rated at 290 HP (made closer to 350) and would spin to well above 7000 rpm. It actually didn't make any power below 3500 rpm. BTW only transmission available was a Muncie 4spd and the standard gear set was 3.73 (should of been 4.88's).
    Feb 2006
    MD
    My shift points are set at 7100rpm (peak power at 6900rpm) and my combo isn't anything special. Just a heads and cam setup with some quality lifters/valvesprings and ARP rod bolts in a stock bottom end.
    Six Speeds Inc I believe has a naturally aspirated ~440" LSx turning well over 9000rpm. Check YouTube for the video.
    Philly+Glenmoore, Pa
    Pewter Metallic
    2002 Trans Am WS6 M6 D1SC
    Quote Originally Posted by nmssr08 View Post
    The new M3 revs that high cause like was was said, it has a smaller displacement. Its only 4.0 Liters with a 12:0:1 comp ratio. Makes a nice 414 hp at 8,300 rpm but a low 295 lb-ft of torque at 3,900 rpm. At least is consistent, (85% of the maximum torque available through 6,500 rpm).
    Its possible to wind out an LS motor that high buts its gonna cost some coin.
    Member iam_dale's Avatar
    Bann, Germany
    02 WS6
    Quote Originally Posted by 9T8W66 View Post
    Word I got on 'em was that you had to put it in neutral, punch the throttle, and wait 5 minutes for the dayum thing to blow up!!
    dale
    JUISSED Midnight02's Avatar
    Feb 2007
    Atlanta
    2002 Camaro SS
    Great question. There are plenty of guys that are revving in the 6800 - 7000 rpm range and I'm sure you will likely find an occassional example of a build that could go to 8000 - 9000 rpm. That being said, most of the folks on this site are probably spinning somewhere between the stock redline and 7000 rpm.
    Personally, I have a typical H/C/I setup and have the drivetrain mods to support it and I make my max power at 6400 rpm and usually shift right around 6500 rpm. Frankly, by 6500 rpm with the cutout open I couldn't even begin to imagine what it would sound like if I stayed in it much longer.
    2002 Camaro SS M6, 2.5 PRC 5.3L heads, TFS 228/230 cam, FAST 92, bolt ons + a 10 lb bottle in the back.
    1989 Corvette L98, A4, Full bolt ons, etc.
    Jan 2008
    SoCal
    thanks for the info guys. i see that it is possible to have ls1 rev high but i guess the torque is gonna drop and it cost a lot of money. revving to 8500 rpm sounds fair enough and i guess changing rods/pistons are always better for extra protection..... what parts brand is good for this type of build? any particular brand you all recommend?
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    i think the m3 is able to do so also because it doesnt use pushrods and such
    Feb 2006
    MD
    You'll need A LOT more than just rods and pistons to spin 8500+ rpm.
    i'd would want to rev that high... if anything get a cam, valve train components and heads and adjust your rev limiter to that cam so you can drop back in to peak HP range with out loss... reving high like that will more than likely put you on the down fall of your HP range and you will run slower times all together unless you have a massive cam...
    Aurora IL
    Trans Am owner
    former
    also, you can get more revs with lighter weight.
    you would need a lightweight crank, aluminum rods, and titanium valvetrain to spin that high and let the motor survive.
    if you are serious about it.....Callies makes some badass crankshafts. I believe GRP makes custom billet I beam rods ($100+ each) and venolia makes really badass custom pistons.
    of course with that bottom end....you woill be sittin on a easy $7,000+ for the roating assembly parts.....that doenst include the extreme duty block of your choice, or machine work......
    Member Eric1987's Avatar
    Long Beach, California
    1999 Z28 Convert
    Realistically what would it take to even get my redline at 6300? And power benefits?
    Senior Member Bottesini's Avatar
    Denton, Texas soon Lafayette, Louisiana
    Blue
    2002 Z28 Camaro M6
    Quote Originally Posted by Eric1987 View Post
    I shift between 6500-6800. Only things that where needed, exhaust, lid, cam (226/228 .585/.588 lsa 112), and a tune. The 02s have a better rod bolt then the 99s from what I understand but just getting a little more RPM is not that hard. However, you don't really get much of a gain unless you have the parts to make power up there.
    Jan 2008
    SoCal
    thanks everyone for the great info. I don't think I want to spend over $5000 to build my motor...... quality parts are always good.....but if there are more cons than pros to rev high, i don't think i want to proceed with a build. i guess getting a good amount of HP/TQ will make up for the high rev anyway right?
  1. Your thoughts on a high revving LS2
    By nickdex87 in forum Internal Engine
    Last Post: 05-16-2012, 04:34 PM
  2. engine revving on home page?
    By 0verkill in forum Almost Anything Goes
    Last Post: 07-25-2011, 02:35 AM
  3. Higher revving LS motor
    By cfgioja in forum Internal Engine
    Last Post: 09-11-2010, 04:59 AM
  4. Sudden Revving
    By 02C5Rocket in forum General Help
    Last Post: 07-02-2009, 01:02 PM
  5. slow revving?
    By dirtybird222 in forum General Help
    Last Post: 03-08-2007, 07:21 AM
