Thread: Bad knocking
    1998 camaro z28
    Bad knocking
    I had a missfire in the #2 cycl. found out it was a striped spark plug, so I pulled the head and heli coild it. Igot it all put together, but when I started it up there was a nasty metal click&knocking noise. could it be from over torq. the rockers,or from driving for a month with a dead cycl?
    USA
    BLACK
    Z/28 LS1
    Did you use a torque wrench and torque to specs? Aluminum heads.
    old timer blue02Z's Avatar
    2002 Z28
    wy did you pull the head in the first place for a misfire? could be wrong torque or a loose rocker
    1998 camaro z28
    Ipulled the head becaused a spark plug was streped ouy and that was the only way to get it out, and no I didnt use a torq. wrench on the rockers, but I know to torq 22ft.lbs
    2002 Z28
    post up a sound/video clip...
  1. Help: top end knocking
    By 2000dreambird in forum Internal Engine
    Last Post: 02-23-2011, 02:07 PM
  2. Help: Knocking noise
    Last Post: 11-01-2010, 03:54 PM
  3. knocking when I gas it
    By LETHALxLS1 in forum General Help
    Last Post: 08-05-2007, 06:43 PM
  4. weird knocking....
    By camaross2000 in forum General Help
    Last Post: 05-01-2007, 03:23 PM
  5. KNOCKING noise
    By ls1hoon in forum Internal Engine
    Last Post: 03-12-2007, 09:50 PM
