Results 1 to 10 of 10
    Junior Member 98ls1t/a's Avatar
    Sep 2008
    Massachusettes
    Bright Red
    1998 Pontiac Trans AM
    Monsoon Speakers
    The factory/DELCO speakers for my Monsoon stereo in my 98 Trans Am keep blowing out. I have repaced them twice so they cant handle the wattage of the amp. Doe any one have any suggestions on a replacement speaker for the sail pannel that will fit into the stock housing and wiring? Thank You
    Feb 2006
    2002 WS6
    yea, don't turn it up so loud and pull back the EQ levels. You are over driving the speakers thinking that you are getting more volume out of them. You are just creating noise. If you want more bass, ditch the system for a couple of 18s and some amps and crank 'er up.
    Sep 2008
    Massachusettes
    Bright Red
    I am not after getting more bass, I just dont want my speaker(s) to make that crackle sound. I really dont crank them up that loud often but certain songs sound bad.
    Feb 2006
    2002 WS6
    if its only certain songs what are you using to play them back with? I ahve found the most free MP3 files are horribly overgained and what you are hearing is infact the medium clipping. Digital files are really sensitve to that.
    If it were you speakers, you would hear it with every song. Try playing the songs that crackle on a better system and then compaire them to one that does not.
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    It is not the wattage it is the distortion they cant handle, too much heat. There are upgrade speakers that will fit. Check the stereo section of the forums, there is a lot of threads on this that can help you out.
    Feb 2006
    2002 WS6
    You need to learn some basic audio theory. Wattage is the amount of signal/voltage sent to the speakers measured loosely in watts. Over driving the speakers will heat the coils and cause the speaker to over travel.
    Distortion is the result of that over drive as the speakers are unable too keep up. Upgraded speakers are always good.
    You can also over drive the source signal before the amp and that too will cause audiable distortion if it is high enough or you have a trained ear.
    Feb 2006
    Orange County, NY
    always dirty
    I am not here to argue audio theory. I am saying that better speakers will hold up better.
    Member Z ROADSTER's Avatar
    Shreveport,Louisiana .USA
    PEWTER
    2002 Z/28 VERT.
    I read somewhere that GM came out with some replacement speakers that super-ceded the older model speakers that will better handle the power of the monsoon system . I too had problems with blown front speakers and I'm 64 years old so you know I'm not twisting on that volume button . But after useing GM's new replacement speakers I've had no problems after a years worth of top down blasting .
    Junior Member 98T/A.SNAKEATER_'s Avatar
    Broken Arrow,OK
    1998 pontiac Trans Am
    just spend the money and buy some component speakers infinity has some for like 250 bucks and they come with tweeters that fit right into your stock kick panel and they are screamin loud you prolly want to invest in a deck also for the proper wattage and sound settings... check out crutchfield.com
    Sep 2008
    Massachusettes
    Bright Red
    Quote Originally Posted by 98T/A.SNAKEATER_ View Post
    I want to keep the factory deck but those speakers seem to be a good way to go. My speakers have not crackled in a few days but when I here a song with massive bass it sux. Thanks for the help, I don't know alot about audio, just drivetrain and body.
  1. Monsoon speakers
    By 02silverbird in forum Parts Wanted / Trade
    Last Post: 06-09-2010, 06:17 AM
  2. Help: Monsoon speakers
    By trixysrace11 in forum Firebird / WS6
    Last Post: 02-18-2009, 05:52 AM
  3. Monsoon Speakers, NEW IN BOX
    By stinkfinger in forum Parts For Sale / Trade
    Last Post: 03-12-2006, 09:16 PM
  4. Monsoon speakers?
    By Tucdog in forum Parts Wanted / Trade
    Last Post: 11-17-2005, 10:53 AM
  5. Where to by monsoon speakers
    By Daniel P. in forum Stereo and Electronics
    Last Post: 10-04-2005, 02:31 PM
