Thread: head porting ?
    🤔 11s. blackbirdbrain89's Avatar
    hagerstown, mercersburg
    black trans am
    2000
    head porting ?
    on im geting my parts to geather for my 4.8 head swap on to my 00 t/a, im starting with the heads i have the valves i want and now im to the porting.. how the hell do u mark off the intake side of the heads i know u can use the gasket's to mark them and port to size but with the o rings it makes it a little on the hard side
    Next, on the ex side the only gaskets i can get ahold of are the fel pro ls1 1.85" if i try to go all the way to 1.85 am i going to run in to a coolent passage? some one gotta know.... btw the 4.8 heads are the same other then the cc in the com chamber is smaller
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    I assume you are talking about gasket matching? Get a scribe... a rod with a sharp point on it and scribe along the edge of gasket. With aluminum heads you have to be extremely careful when porting. You will take alot of material out quickly using wrong material's etc.
    Also keep in mind, you can make your heads flow worse with a piss poor port job.
    When you get better try a tear drop around the valve and some pocket porting. That is when you start seeing 's in CFM's.
    You need a flow bench and lots of experience to accurate port a head really. Why do you think people pay good money for others to port?
    Good luck.
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    I will check to see if I have a spare intake gasket for my aluminum intake. If I do, I will bring it to the track ! If not, summit racing...
    Feb 2007
    St Thomas, PA
    Found a Gasket !!! It's in my trailer. I will be at the track tomorrow. PM sent...
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by bills98ta View Post
    i still have a new set of paper header gaskets if you want them too
    black trans am
    2000
    i have the header gaskets but there 1 7/8 and i dont think im going with headers that big and hipo i know how to port and polish i know quite a few eng builders and did 3 sets of head when i was in school i even cc the heads when i was in school. i plan on cc the heads b4 i start the polishing cc is not a good as a flow bench but im not building a all out drag car im just trying to get low 12 high 11's
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by blackbirdbrain89 View Post
    the gaskets I have are for a set of pacesetters so they are alittle smaller than the ones you have if you want them i could even drop them off.
    i run through Greencastle to Williamsport every day to get to work so anywhere in Hagerstown is close for me
    Florida
    1999 TA WS.6
    Sounds like we went to the same schooling!
    black trans am
    2000
    i went to a tech high and was always helping my teacher out building his little old 5.0 mustang at the same time i was learing about the ls1, i was trying to make my v6 fire bird fast but soon gave up. and started saving up for my car now.. now i have some thing worth making fast
  1. Two New Head Porting Options - Dialing-In The D-PORT
    Last Post: 05-19-2011, 01:20 AM
  2. Wanted: porting disc for head and intake porting
    By crossbredfoxbody in forum Parts Wanted / Trade
    Last Post: 01-10-2010, 12:28 PM
  3. CNC Head porting
    By Bowtie Guy in forum Western Members
    Last Post: 11-24-2009, 01:33 PM
  4. Porting TB
    By ls1camino in forum External Engine
    Last Post: 10-15-2008, 02:35 PM
  5. Porting the MAF
    By drummer52910 in forum External Engine
    Last Post: 09-11-2007, 09:15 AM
