Results 1 to 13 of 13
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    new to tuning and want to get some of the basics
    hey guys..i will be getting hp tuner pro here soon for my car..a 98 trans am..and i have a question. If i want to do live tuning etc while my car is running...do i need to get a 99+ pcm ? also if i do...what do i need to do to get it to mesh with my car thanks guys.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    yes, you will need to step up to a 99+ PCM. the 98 PCM just doesn't have enough capacity to handle live tuning. there is some pinout changes or an entire wiring harness change. i'm not sure which.
    Shepherd, Michigan
    98' trans am
    ok..i will take a look into it..hows it going R ?
    orlando, fl
    2014 camaro 2ss/rs
    pretty good. i really like the victor jr setup. once i convert to the 4L80E trans, i'll get some new timeslips.
    Shepherd, Michigan
    98' trans am
    nice you selling your old converter ? i might be in the market for one in a lil
    Shepherd, Michigan
    98' trans am
    cant wait
    Shepherd, Michigan
    98' trans am
    wow seems like i need to repin to a 99+ and even after that. my fuel gauge wont work that kind of sucks
    orlando, fl
    2014 camaro 2ss/rs
    this is a next year project.
    Shepherd, Michigan
    98' trans am
    always something to do each year
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    The gauge can be made to work with a segment swapped from an express van...
    Shepherd, Michigan
    98' trans am
    see now i herd that..but i thought i needed to be running efi-live to do that..and hp tuner didnt have that offered
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    It can be done by HPTuner's support and some other folks.
    Shepherd, Michigan
    98' trans am
    frost thank you..you just made my day...now i need to get the pin layouts of the two and go searching for pcms
  1. Dyno Tuning Basics - Jets, Timing, Camera, Action
    Last Post: 04-12-2008, 12:57 PM
