    Member Goldcuffs's Avatar
    Aug 2008
    Florida
    2000 Trans Am
    Tru-Fiber fitment issues
    Hey guys, is there any tricks to manipulate the shape of a fiberglass hood? The left front corner near the headlight sticks up about a 1/4 inch too far.(it's not the bump stop) The gaps are huge at the head lights but other than that it seems to fit fine. I guess I should have bought an OE but oh well.
    Member Piranhaz's Avatar
    Aug 2008
    Minnesota
    1999 Trans Am M6
    Quote Originally Posted by Goldcuffs View Post
    Do you have the hood bolted to the hinges yet?? If so, take them out. First thing to do is lay the hood in there without anything attached. Make sure that you can get it to match the body lines before anything else. If it doesn't line up that way, you have trouble. I know that I had to ream out the holes where the hood bolts to the hinges to give me more adjustment. Just take your time and you will get it dialed in. And no, there is no way to "manipulate" the shape of the hood. I talked to a guy at Tru-Fiber and he said they are all pre-fit. Once I messed around with it, it actually fits very nice. Just remember, you have a lot of adjustment on the headlights and the tops of the fenders.
    Good luck.
    Aug 2008
    Florida
    2000 Trans Am
    ok, I'll give that a shot. Thank you.
    Senior Member GULLETT17's Avatar
    Muncie, IN
    00 TA PWTR, 98 VertTA NBM
    80 TA BLK, 80 Formula NBM
    piranhaz is right, our headlight covers have a lot of adjustment in the them; up, down, and side to side. . . that was the main alignment issue i had with my ws9 hood. be patient and itll line up fine
    Aug 2008
    Florida
    2000 Trans Am
    I don't think the headlight gaps will be a problem but the hood actually sticks up past the fender, I have to push it down with my hand and then it springs back up.
    Aug 2008
    Minnesota
    1999 Trans Am M6
    I had the same issue but on the passenger side, it just took some adjustment. Make sure you contact the company you bought it from ASAP if you can't get it to fit properly. Also take pics to show them.
    Has your car ever been in an accident???
    Aug 2008
    Florida
    2000 Trans Am
    Yes to the accident. I bought it wrecked. I think I got lined up pretty good.I had to drill the hinges and add some shims but it looks pretty good now.
    Aug 2008
    Minnesota
    1999 Trans Am M6
    Cool!! I had to drill out the hinges a little bit too, but no shims. Doesn't matter though, get it to fit nice and nobody will ever know!!!
    Aug 2008
    Florida
    2000 Trans Am
    This is my problem.
    Aug 2008
    Minnesota
    1999 Trans Am M6
    This is my problem.
    Can you tell if the hood appears to be symmetrical?? If so, then I would have to believe it's the fender/radiator support that low at the front. Did you remove the bump stops completely?? Also, was the car hit on the drivers side? You said it was a builder, just wondering if they didn't get the drivers side pulled up far enough.
    Aug 2008
    Florida
    2000 Trans Am
    This is the before. The pics above are with the stops removed.
    Aug 2008
    Minnesota
    1999 Trans Am M6
    So it appears there was no frame damage. You might just have to loosen all bolts on the driver fender and possibly the bumper and just start tweeking. I wish there was an easier way.
  1. Fitment
    By will4242 in forum Wheels and Tires
    Last Post: 05-09-2014, 02:59 PM
  2. fitment issues with FAST intakes on C5?
    By MachWon in forum Corvette
    Last Post: 03-01-2010, 12:21 AM
  3. Tru-Fiber fitment issues
    By Goldcuffs in forum General Help
    Last Post: 10-02-2008, 06:16 PM
  4. headlight fitment issues
    By kebie05 in forum Appearance Section
    Last Post: 10-08-2007, 11:45 AM
  5. Replies: 0
    Last Post: 01-31-2006, 11:05 AM
