Thread: FAST 92mm Intake
09-25-2008, 08:46 PM #1Member
- May 2006
- Canada
Blue 1997 Trans Am(Sold)- Pewter 2001 Trans Am Vert
FAST 92mm Intake
A couple of questions about the FAST 92 can't seem to find anything in the search.
question 1- what is required when you paint a FAST intake? I want a smooth finish and not textured. Is there sanding involved? What is the best paint to use for the job? Does it have to be for a certain heat level?
question 2- What is all involved when porting a FAST 92? I've yet to see a write up for it. Any help is appreciated...
09-27-2008, 09:24 AM #2
as far as painting it goes, to get a good smooth finish that you want, you need to to do Alot of hand sanding and get the plastic nice and smooth to your liking before you paint it. you might not need it but, id go with a high temp paint to be safe.... id hate to go through all the work to get it the way you want it, then have the paint peel because it got alittle hot
Ive honestly never seen a fast intake in person, but if you have all your gaskets id just smooth and match the ports to them
09-28-2008, 08:49 AM #3
Try a quick search next time. Its a great feature.
http://www.ls1.com/forums/showthread...=painting+fast
09-28-2008, 12:39 PM #4Member
- May 2006
- Canada
good call but I did try a search on here because I figured this would be the obvious place to find it... I later searched the "appearance section" and found that thread....
thanks though.
10-01-2008, 10:02 AM #5
10-01-2008, 02:04 PM #6
Another thread on the porting. http://www.ls1tech.com/forums/showthread.php?t=941863
Wanted: FAST 90/92mm Intake
By mbmta99 in forum Parts Wanted / TradeReplies: 1Last Post: 03-04-2012, 05:36 PM -
2000 ss ls1..fast 92mm intake ported?
By gmc444 in forum External EngineReplies: 0Last Post: 07-21-2009, 08:28 PM -
92mm v. 90mm Fast Intake
By Ghawk996 in forum External EngineReplies: 11Last Post: 12-19-2008, 04:59 AM -
Fast Intake 92mm v 78mm
By Ghawk996 in forum External EngineReplies: 4Last Post: 10-09-2008, 08:38 PM -
Fast 92mm Intake and TB
By WS6ICK in forum External EngineReplies: 6Last Post: 05-27-2008, 05:06 PM
