Results 1 to 2 of 2
Thread: Counter shaft breaking??
09-19-2008, 08:44 PM #1<b>"iznuthn"2 a BOSS!</B>
- SF,CA
- Blog Entries
- 1
ONYX BLACK- 02 Z28
Early 2008 I finally fixed my T56. Nearly a whole year passed knowing that she had no 5-6 & reverse. Until my tax refund came I finally took her to get checked out.
The counter shafts teeth broke where it connects with the other half??? This happened on the freeway one day and I downshifted to 5th had nothing but high revs.
Has this happened to others or was I ripped off by the tran shop?
09-22-2008, 06:17 AM #2Member
- metro Detroit area
There are (I think) 6 lugs that engage the couter shaft extension to the main countershaft. I have seen these break. I don't think the all go at once but when that last one goes you will loose 5th 6th and reverse. Be sure they properly shim the rear cluster extension on the rebuild( it will have to be replaced). A careful look at the mating lugs on the main clustergear should be done. If they have any cracks ( magna flux), the cluster should also be replaced.
Counter Strike: Source
By KnightmareWS6 in forum Computers / GamingReplies: 8Last Post: 05-15-2010, 09:15 PM -
Over the Counter Wax
By chuckie669 in forum Showcar and DetailingReplies: 5Last Post: 04-03-2009, 05:44 PM -
Drive shaft breaking? too weak??
By NightRiderZ in forum General HelpReplies: 2Last Post: 07-30-2007, 03:19 PM -
Counter Strike Source Gripe
By ThackerSS in forum Almost Anything GoesReplies: 1Last Post: 05-21-2006, 08:40 PM -
Anyone have a counter-top deep fryer?
By Warbird in forum Almost Anything GoesReplies: 18Last Post: 05-16-2006, 08:21 PM
