Results 1 to 3 of 3
    Member Justin93's Avatar
    CANFIELD, OHIO
    PEWETER METALIC
    2002 CAMARO Z-28 M-6
    2002 ls1 Crank Freeze plug P/N
    I need the P/n for the LS1 crank Freeze Plug!!! Pictures would help too as Mine has a hole in the dead center of it and I think it was caused by the original Pilot bearing tool, unless that hole is supposed to Be there. note it is in the center of the freeze plug, The freeze plug is still in the crank!
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    go to your local parts store and ask for a 1" freeze plug. not supposed to have a hole in it.
    orlando, fl
    2014 camaro 2ss/rs
    here's the part number
  1. anti-freeze
    By edrvsqz1980 in forum Firebird / WS6
    Last Post: 10-04-2010, 08:28 AM
  2. LS1 (2002) spark plug change tips
    By cold_surfer in forum General Help
    Last Post: 05-02-2010, 09:19 AM
  3. Freeze plug size
    By DarkMesa8 in forum V6
    Last Post: 07-14-2008, 06:55 AM
  4. Anti-freeze
    By wnmech in forum Internal Engine
    Last Post: 11-27-2006, 06:11 PM
