    quicky06
    Guest
    Side exausht(i cant spell)
    well heres the deal im planning on making a custom exauhst setup in the neer future. and i am debating between going out the side before the wheel wells or going all the way out the back.
    either way it will be true duals with cats and bullet mufflers.
    what u think?
    The milks gone bad!! Devylyst's Avatar
    East Point, Ga
    86 Z28
    I think this idea has been attempted before, but didnt work cause of the SFC before the rear wheels, but anything is possible.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    http://ourworld.cs.com/jrp98ls1/Dual+1.jpg
    http://ourworld.cs.com/jrp98ls1/side+exit+1.jpg
    It's an LS1tech girl, other than that I don't know anything, but now you know how it looks coming out the side.
    Member ProwlerZ's Avatar
    Myrtle Beach
    2002 Z28
    In general the idea doesn't work very well. I had two systems bent for it, and you either run the system an inch off the ground, which will lead to the prompt removal of the exhaust system (if you're lucky, that would be all that comes off), or you route it back towards the front, cut to the sides just before the front axle, then weld subframe connectors in and use flat piping to run it back. This fit and looked well, but the fact that you are "U-ing" the pipes means your air-flow just goes to crap. You've also got to be careful with excess airflow, once you've heard a 6 cylinder with a cut-out, you'll know what I mean.
  1. No Need for Spell Check
    By 024mula in forum Almost Anything Goes
    Last Post: 11-12-2012, 10:03 AM
  2. Dry Spell
    By V8MUSCLE in forum Almost Anything Goes
    Last Post: 11-16-2010, 08:58 AM
  3. HPtuner, are there instructions that spell it out?
    By Firebirdjones in forum Computer & Tuning
    Last Post: 02-24-2007, 03:00 PM
  4. hey third shift... spell information for me
    By predator in forum Almost Anything Goes
    Last Post: 08-17-2006, 02:31 PM
  5. Babs has no spell checker
    By Element187 in forum Political / Debate Forum
    Last Post: 03-07-2006, 04:17 PM
